Lift kits
  • supergaz
20 Feb 2011 10:11 #11837 by supergaz
Replied by supergaz on topic Re: Lift kits
Sorry bad one.
I agree over 3' then corrected arms are needed. There are some 3' correction bushes available, however I don't fancy them.
  • Monkey
20 Feb 2011 10:43 #11838 by Monkey
Replied by Monkey on topic Re: Lift kits
I'm a using castor correction bushs but as you can see in the pic above 3 deg offset bushs are not enough for a 80mm lift. My castor angle it still out by 1deg from what suzuki recommend i think it is +0.55deg to +1.00 deg mine are currently -0.55 degrees. I will be getting new cromolly front radius are which are 25mm longer than the standard. This will make the castor angle perfect and making the wheels base a little bit longer than factory and will give me slightly more flex to.
  • gazert
20 Feb 2011 16:07 #11847 by gazert
Replied by gazert on topic Re: Lift kits
Monkey wrote: Any thing over 2inchs of lift castor correction bushs should be used and in my opinion anything over 3 inchs corrected trailing arms need to be used!
P.s. Gary if you had yellow springs why would you be eating them? sorry i don't see the humor in that.
Cus his springs are banana shaped!!!!!!
  • Monkey
21 Feb 2011 09:45 #11910 by Monkey
:laugh: argh good one.
  • biggaz
21 Feb 2011 11:42 #11912 by biggaz
Replied by biggaz on topic Re: Lift kits
pahh, caster bush's are for girls i heard.
  • Monkey
21 Feb 2011 11:52 #11916 by Monkey
Biggaz: they may be for girls but i really don't wont my castor angle to be out by over -3deg from what suzuki recommend, and put unnecessary strain in other suspension components.
Time to create page: 0.257 seconds
