Buying a 2002 Jumny
- Ryland
26 Jan 2011 19:52 #10401
by Ryland
Buying a 2002 Jumny was created by Ryland
Help, My hubby and I went to look at a 2002 model yesterday, this it the first one we have seen, it had a lot of grease on the ball joints is that normal? also tested the 4wd , it made a noise when the 4wd was engaged and I drove very slowly on full lock and the wheel juddered quite alot, almost kangaroed. Is this normal or should we walk away? please help
- darthloachie
26 Jan 2011 20:00 - 26 Jan 2011 20:01 #10403
by darthloachie
Replied by darthloachie on topic Re: Buying a 2002 Jumny
The jimny doesn't have a centre diff so when you engage 4wd and put full lock on you will get a juddering as all the wheels are trying to turn at the same speed and when you are turning the inside wheels turn slower
Ideally you should not engage 4wd and put full lock on if the ground is hard as it can break a front half shaft
By all means test the 4wd but do so in a straight line
Last edit: 26 Jan 2011 20:01 by darthloachie.
- Ryland
26 Jan 2011 20:01 #10404
by Ryland
Replied by Ryland on topic Re: Buying a 2002 Jumny
thanks for the reply, what about the noise when I engaged the 4wd, is that normal?
- Ryland
26 Jan 2011 20:03 #10405
by Ryland
also the grease on the ball joints?
- darthloachie
26 Jan 2011 20:16 #10406
by darthloachie
can't really advise on the balljoints as I bought mine as a modified offroader so everything underneath was mud brown coloured
You will get some more noise in 4wd as all the front prop and half shafts etc are driving but again mine has no carpets and a few creaks and rattles any way.
I would advise you see and drive as many as you can - even annoy the local suzuki dealer and get test drives of newer models to compare ( even if you never intend to spend that much money)
I am sure some of the other people on here with more standard trucks will be along soon to give their opinions
happy hunting
happy hunting
- Ryland
26 Jan 2011 20:18 #10407
by Ryland
thankyou you have been very helpful
Time to create page: 0.178 seconds
