2 inch spring lift
  • jimnyjim
25 Jan 2011 19:58 #10358 by jimnyjim
2 inch spring lift was created by jimnyjim
hi im a new member from plymouth havent had my 2004 jimny that long i use it mostly on road but like a little play off road :) if i got a 2inch spring kit would i need to get the adjuster bars as ive herd when you lift jimnys the axle moves over :unsure: or should i get spring spacer kit
  • dirtydogz
25 Jan 2011 20:24 - 25 Jan 2011 20:29 #10360 by dirtydogz
Replied by dirtydogz on topic Re: 2 inch spring lift
2 inch spring lift will be ok,it's with the 3 inch lift you have to extend the panhard rods.B)
Hope this helps .
I have 1.5 inch spring spacer with 205/75/15.
Last edit: 25 Jan 2011 20:29 by dirtydogz.
  • jimnyjim
25 Jan 2011 20:45 - 25 Jan 2011 21:12 #10361 by jimnyjim
Replied by jimnyjim on topic Re: 2 inch spring lift
thanks for the reply mate ive got 195/15 kumho kl71 mt on but standard suspension, do the spring spacers make much difference ? how does it handle , whats it like in high winds, can you see the hight once fitted ? where did you get yours from cheers jim :)
Last edit: 25 Jan 2011 21:12 by jimnyjim. Reason: mistakes
  • dirtydogz
26 Jan 2011 07:17 - 26 Jan 2011 09:24 #10368 by dirtydogz
Attachment 056.JPG not found
WITH 205/70/15
WITH 205/75/15
Attachment DSCF1286.JPG not found
Helps if you go for bigger tyres,Handles OK in high winds,Ride is a little bit harder but I like it that way.
Will give you a 1.5 inch lift as you can see with the 205/70/15.
Spacers are from BITS4VITS or BIG JIMNY about £84+vat.
DIRTYDOGZ. www.bits4vits.co.uk/store/index.php
Last edit: 26 Jan 2011 09:24 by dirtydogz.
  • jimnyjim
26 Jan 2011 11:40 #10372 by jimnyjim
looks good may have to invest in them beauties :) thank you for your help i will look around get some then will post some pics of my jimny with them fitted thankjs again :)
  • Strek
26 Jan 2011 16:45 #10385 by Strek
Replied by Strek on topic Re: 2 inch spring lift
dirtydogz wrote: 2 inch spring lift will be ok,it's with the 3 inch lift you have to extend the panhard rods.
Sure about this? I have a feeling I have read somewhere that this might be individual from car to car, and different liftkits etc. Can anyone confirm that its not needed on 2"?
I have just received my 2" procomp kit, but I havent had the money for adjustable panhard rods yet. If I dont need them, I dont have to wait to install the kit! If so: Great!!!
Time to create page: 0.256 seconds
