Jimny Peugeot XUD9 conversion
18 May 2026 20:37 #264463 by dan89
Hi,
I am planning on converting a 2002 Suzuki Jimny to diesel, with a Peugeot 1.9 XUD9 engine.
I’ve already started collecting some bits, I’ve got an engine from a Vitara which actually used the XUD9 engine from the factory.
I’ll be swapping the Lucas fuel pump for a Bosch one, as they run well on waste oil.
The engine is going to be mated to an LDV pilot gearbox which I have coming. These were rear wheel drive and used the non turbo version of the Peugeot engine so they bolt straight on.
I’ll need to see work out clutch slave/ fork, as the Jimny uses cable and the LDV used hydraulic. Will probably fit a hydraulic master cylinder to the Jimny.
Also not sure on clutch choice yet.
Has anyone ever done this conversion or any experience with the XUD9 engines.
Any advice much appreciated.
Thanks
Dan
The following user(s) said Thank You: CelicaRacer
Time to create page: 0.178 seconds
