K14C in 99 G-Series Swap
- Abort Abort
11 Dec 2022 23:52 #246312
by Abort Abort
Other things may be easier with an M swap, but they are fairly minor. It will still be a stand alone ECU, or get the factory loom / ECU and deal with all the shenanigans there. Then the M18A is still hard to find which leaves really only the M16A.
So at the moment an M swap is a possibility, but doesn't seem like a huge saving of effort or cost over the K14C, but that engine is newer with less kms and quite a bit more torque. Plus it's newer, with far less kms.
As for doing other swaps: It is something I've definitely thought about. There are a few popular engines that are well known for running stand alone that could be great. Honda K20 for example. But I don't need all that in a tiny Jimny and because of their desirability for their purposes, they end up being more expensive and a lot more kms. Plus the K14C is very compact. It is designed for this size of vehicle whereas the K20 is really more for something bigger and while they've been shoehorned into all sorts of things, I think the K14C is better for for purpose.
Saying that, if you've got other suggestions that are maybe a bit more well documented in happy to listen.
I'll keep investigating the M swap as it would work well IF the stars align for all the right bits.
Replied by Abort Abort on topic K14C in 99 G-Series Swap
Yes, the R7ME bolts up AFAIK. I'm making a guess because info is a bit scarce but I believe things like engine mounts from that series should also work. However I think you do have to do a fair bit of modification to the gearbox setup to make it work due to other differences beyond the bolt pattern. I believe it's a hydraulic clutch vs a cable, but happy to hear from anyone who has done it.The M series engines mate to R72 gearboxes, as that combination was fitted to 2000-2004 models. I believe the bell housing bolt pattern is the same as the G?
Aside from the ECU, going to an M series is a very straight forward swap and every part you need is available off the shelf.
If you're certain you want to deviate from what's easy then why stick with Suzuki engines? There are loads of other engines that would work great and be no more work to install than the K14C
12 Dec 2022 00:07 #246313
by Old Neil
Sent from my SM-A336E using Tapatalk
Replied by Old Neil on topic Re:K14C in 99 G-Series Swap
I wish you all the best in your project, be interested to see how it works out, take lots of photosAbort Abort wrote:
12 Dec 2022 07:09 #246316
by Busta
Replied by Busta on topic K14C in 99 G-Series Swap
Sorry, I'm getting my gearbox codes mixed up. I meant R7ME, as used in all manual Jimnys up until 2005. Basically the M series will bolt up to your existing gearbox. What gearbox do you plan on using with the K14C?
I've done a couple of M16 swaps and it's a good engine, well suited to the Jimny. Noticeably more power than standard and tows well. Better than the G16. The Jimny drivetrain isn't built for lots of torque so be wary that you may come into other issues.
Re. other engines, do you have any Fords with the 2.0 Duratec over there? It's a great engine, 150hp and lighter than the M series. It's used in lots of engine swaps here, easily tuned to over 200hp and they are cheap.
I spent a year in WA, working on farms in Williams, Katanning, Carnamah, Carnarvon. Regular trips to the Ocean Beach Hotel. Good times.
12 Dec 2022 07:34 #246317
Replied by yakuza on topic K14C in 99 G-Series Swap
The M and G has different bolt patterns at the bell housing.
The following user(s) said Thank You: Busta
- Abort Abort
12 Dec 2022 14:34 - 12 Dec 2022 14:54 #246323
by Abort Abort
The other possibility is swapping in a JB74 K series gearbox. That should in theory mate up to the engine without much drama. Getting it to mate up with the rest of the car on the other hand might be more difficult than using the original box.
I've seen a lot of references to the Duratec on here as a swap option as it seems they are quite ubiquitous in the UK. I do think we have them here in a number of focuses (they were the Focus 2.0 for a couple of generations right?). I mean if there are kits I'd be happy to look at one of those for sure. Especially if they are lighter. I'm not looking at this mostly for power, but availability and to a degree reliability. The K14C is easy as to find here with almost no use because nobody needs to replace them (yet). I had one in a Vitara Turbo for a few years and its an absolutely fabulous engine.
Haha OBH days!
Yeah the R7ME is in the 2000-2005 with the non-VVT M13a. Mine being a G series won't bolt up. I can acquire an R7ME, but I believe it is a bit of a faff to get them working (it's not AFAIK a straight bolt in). Assuming I was doing this swap I would look at fabricating an adapter plate and get a custom flywheel made up and use the existing G series box (which I believe is more robust than the later gearboxes if I'm not mistaken?).Sorry, I'm getting my gearbox codes mixed up. I meant R7ME, as used in all manual Jimnys up until 2005. Basically the M series will bolt up to your existing gearbox. What gearbox do you plan on using with the K14C?
Haha OBH days!
Last edit: 12 Dec 2022 14:54 by Abort Abort.
Time to create page: 0.209 seconds
