Deluxs new black Jimny, Project KZA
18 Dec 2018 08:07 - 18 Dec 2018 08:07 #199136 by Max Headroom
Delux wrote: ! Had one of those weekends where you just cant get the matches to light!
Heheh similar but different- It's a bit like that working big jets with the clowns for managment that we seem to dig up from somewhere - its like trying to work with one arm tied behind your back and blindfold.
In fact in the RAF we had a saying...
“We the willing, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
Last edit: 18 Dec 2018 08:07 by Max Headroom.
30 Dec 2018 15:18 - 30 Dec 2018 20:29 #199712 by Delux
Een update!
Had to turn the Jimny round, so had to refit the rear wheels. Started with giving the brake drums a splash of paint...
[img
20181216_102214 by deeelux deeelux , on Flickr
Slackened off the handbrake cable. Wound the nut off the cable to the last few threads...
[img
20181216_100916 by deeelux deeelux , on Flickr
[img
20181216_101005 by deeelux deeelux , on Flickr
Once the cable had been slackened I removed the rubber cover and adjusted the brakes. I turned the ratchet wheel on the adjuster until a bit of resistance can be felt turning the drum. Then apply the footbrake a few times and recheck. Light resistance when spun means its ok.
[img
20181216_102233 by deeelux deeelux , on Flickr
I then adjusted up the cable at the handbrake until I had 5 or 6 clicks.
[img
20181216_105941 by deeelux deeelux , on Flickr
More observant readers will have spotted I forgot my plain screwdriver and used a small chisel to adjust the brakes, LOL!
My current project is HERE!
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
Last edit: 30 Dec 2018 20:29 by Delux.
30 Dec 2018 15:35 #199713 by Delux
Now the Jimny was facing the other way round I could get stuck into the repairs at the front. Corrosion-wise this Jimny is far less work than my last one but mechanically it is far more labour intensive!
I noticed an oil leak...
[img
20181223_124745 by deeelux deeelux , on Flickr
1st impression might suggest a leaky sump but leaks tend to work backwards so I need to find the signs of the leak at the frontmost point. (Is that even a word? Frontmost?)
[img
20181223_124810 by deeelux deeelux , on Flickr
Could be the oil pump, crankshaft oil seal perhaps? I'm doing the timing belt anyway so the cover came off...
[img
20181223_125107 by deeelux deeelux , on Flickr
Inside the cover was pretty dry suggesting the leak is down the back of the space and not being thrown about leaking onto a pulley.
[img
20181223_125127 by deeelux deeelux , on Flickr
Not much oil on or behind the crank pulley but if you look close something is running down the engine in the background. So now we need to find the highest point of the leak...
[img
20181223_125133 by deeelux deeelux , on Flickr
Bleurgh!
[img
20181223_130146 by deeelux deeelux , on Flickr
Highest point, above pic, is the camshaft oil seal although there is a bit round the rocker shaft plug.
So thats it! Oil leak from the camshaft oil seal! Stick a new one in, end of story.
Or is it?
Why is it leaking?
Could be wear, could be the material has hardened over time.
Then I found this!
[img
20181223_130715 by deeelux deeelux , on Flickr
PCV valve! A blocked pcv valve increases the pressure inside the rocker cover. Excessive pressure has to go somewhere, usually escaping from the weakest point, the worn, hardened camshaft oil seal!
Removed the valve and left it soaking in some brake cleaner. Its only a small spring loaded flap inside. PCV valve seal decided to resign by falling to bits on removal...
[img
20181229_104605 by deeelux deeelux , on Flickr
30 Dec 2018 15:48 - 30 Dec 2018 20:32 #199715 by Delux
After cleaning the PCV valve was refitted with a new seal (courtesy of Bigjimy store!)
[img
20181229_104105 by deeelux deeelux , on Flickr
Camshaft oil seal was replaced. I removed the end camshaft cap cleaned the area. Greased the inside of the new seal and tapped it into place using the old seal as a protector.
[img
20181229_104623 by deeelux deeelux , on Flickr
Rocker cover was thoroughly steam cleaned and treated to a new gasket.
[img
20181227_121745 by deeelux deeelux , on Flickr
Before refitting, I add a pea sized blob of sealer at the tight bits either side of the cam cap. You dont want to put too much on as it may find its way into the engine and block an oil hole. In this pic I've probably applied more than I usually would but the camera button on my phone decided to ignore my finger the first few presses!
[img
20181229_105256 by deeelux deeelux , on Flickr
All built up and cleaned! I'm gonna do a timing belt fitting guide for the wiki unless someone has beaten me to it.
[img
20181229_112639 by deeelux deeelux , on Flickr
I'll take it to work and steam clean all traces of the oil leak but in the meantime, after running for 30 minutes or so the oil leak had not returned!
[img
20181227_105506 by deeelux deeelux , on Flickr
Last edit: 30 Dec 2018 20:32 by Delux.
30 Dec 2018 19:35 - 30 Dec 2018 20:34 #199738 by Delux
To gain access to the timing belt and oil leak I removed the radiator. There are bound to be people reading this now thinking "I've done loads of timing belts and never taken the radiator out!' thing is, it isnt much hassle to take the radiator out and it improves access to everything so much, it is probably faster to take it out than it is to work round.
I started by draining the anti freeze out. I figured if it looked ok I'd probably just pour it back in. I've not sent any for lab analysis but I'm not pouring that anywhere other than the used anti freeze thing at the dump...
[img
20181216_134626 by deeelux deeelux , on Flickr
It has a woody, almost chemically nose with undertones of stagnant water and algae.
While I was in there I attended to the power steering tensioner pulley. The belt had been noisy and was ripe for replacement but I thought I better check the pulleys etc. The idler outer section had completely seperated from the bearing and it was only the belt tension holding it in place!
[img
20181227_104523 by deeelux deeelux , on Flickr
I built it back up with new fan belts. I already had them after buying the wrong ones for my last Jimny on ebay! LOL!
Carried out a full service while its in the garage, genuine Suzuki filters are still available in Big Jimnys store so there is no excuse really. I didnt take pictures because it wasnt that exciting but I was a bit confused by the sump washer.
[img
20181227_122344 by deeelux deeelux , on Flickr
It appeared to have had some sort of cupped washer forced onto the plug, very strange. I'm sure the sump plug is happier now its been fitted with a colapsable mitsubishi washer.
Turning my attention to the nearside wheelarch I could see the front axle was leaking, there was excessive play at the wheel, death wobble at 40mph and the brake pads were worn almost to the metal. There arent many pictures because its messy work and I didnt want stinking kinpin 'grease' all over my phone!
The excessive play appeared to be in the bottom kingpin and the rear track rod end. Usually I would remove both track rod ends, vacuum pipes, brake caliper, kingpins and big seal then slide the whole halfshaft out with the hub and brake disc still on. Which is fine when working on a ramp in a large dealer workshop. However, when working in the smallest workshop that can legally be described as a lock up there isnt enough space to slide the shaft all the way out so I had to remove the hub assembly.
Having removed the complete hub assembly I tried again, only to find there still wasnt enough space! I had to remove the cv joint before I could get the so**ing half shaft out!
This is how it looked after removing the shaft...
[img
20181227_144243 by deeelux deeelux , on Flickr
Yeah, I wish! Trowelled out all the stinking grease/CV grease/gear oil/mud slop. I had hoped I could get away with changing the oil seal, adding spacers to the kingpins and sticking it all back together. This was the plan until...
[img
20181223_140544 by deeelux deeelux , on Flickr
I removed the bottom bearing to clean and check it. Familiar scene?! Kingpin bearings promptly ordered!
Its all back together now.
[img
20181230_123052 by deeelux deeelux , on Flickr
[img
20181230_123109 by deeelux deeelux , on Flickr
Well, sort of! As I am off work I have to rely on ebay/Bigjimny for parts, usually thats fine but this time of year is a nightmare to be waiting on parcels. Then some blundering fool ordered the wrong side of track rod end! The disappointment faded a bit when I realised the boot it burst on the front track rod end so I can use the wrong one for that!
[img
20181230_123120 by deeelux deeelux , on Flickr
Last edit: 30 Dec 2018 20:34 by Delux.
  • Venter
30 Dec 2018 21:33 #199741 by Venter
Replied by Venter on topic Deluxs new black Jimny, Project KZA
Great thread, great info, keep it coming!
Time to create page: 0.259 seconds
