Deluxs new black Jimny, Project KZA
09 Dec 2018 15:39 #198795 by Delux
Ann Update!
This week my Jimny has kept Paypal and the postie busy
[img
20181208_134613 by deeelux deeelux , on Flickr
First on the agenda in the Hot rod shop was the gaping crater in the boot. My corrosion assesment tool was deployed
[img
20181209_123109 by deeelux deeelux , on Flickr
I do not claim to be a panel beater and in an ideal world I'd be lifting the body off and spot welding a new boot floor in. However, in the real world I am just a mechanic with a welder and a patch is a decent enough
[img
20181209_121432 by deeelux deeelux , on Flickr
Then blasted it with some etch primer
[img
20181209_122054 by deeelux deeelux , on Flickr
Etch primer is good for repairs like this because it has acid that eats into the metal to stop it flaking off. I'll give it a coat of something better when it is dry
[img
20181209_122127 by deeelux deeelux , on Flickr
At this point I had to stop to refuel
[img
20181209_134631 by deeelux deeelux , on Flickr
Thanks Mrs. Delux!
Part 2 to follow...
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
09 Dec 2018 15:56 #198796 by Delux
Deluxs guide to replacing brake pipes!
My technique is one that has been honed and fine tuned over several years as a mechanic replacing rusty, leaking brake pipes on cars so bad you wouldnt let your dog cock a leg on them. All this while some old, failed mechanic hassles me to hurry up so he can give it back to the customer who assumes they are being ripped off! :laugh:
Anyway, its brakes so you dont want to mess about. The car has a recent MOT, the brake pipes are not the worst I have seen but, using my techniques they needn't be difficult or expensive. Cheap peace of mind is always good, right?
I start by clamping off the rear brakes. I'll be bleeding the whole braking system later but doing this now maintains the fluid level in the rest of the system and lessens the chance of having air trapped somewhere.
Rather than mess about I cut the old brake pipe at the brake pipe end.
[img
20181209_125439 by deeelux deeelux , on Flickr
This means you can get a decent single hex socket on the end and remove it quickly. The original brake pipe ends on my 54 plate Jimny and every other Jimny I remember working on are 10mm.
[img
20181209_130006 by deeelux deeelux , on Flickr
You obviously need to do this either end of the pipe. If you do it 1st, all the brake fluid will have dripped out before you remove it meaning less mess. Next remove the retaining clips
[img
20181209_124639 by deeelux deeelux , on Flickr
[img
20181209_124922 by deeelux deeelux , on Flickr
[img
20181209_125208 by deeelux deeelux , on Flickr
They are 10mm self tapping bolts. If you can get them off 1st time, thats fine but a bag of 10 new ones off ebay is only a few pounds.
Before going any further I like to make sure the bleed screw is good enough to bleed the brakes. I have seen people replace all the brake pipes on a car only to discover one of the bleed screws is blocked/rounded off. No-one likes to see a mechanic cry!
[img
20181209_130220 by deeelux deeelux , on Flickr
09 Dec 2018 16:16 #198798 by Delux
Ok, so if all went well you should have this on the floor.
[img
20181209_125539 by deeelux deeelux , on Flickr
So now we need some shiney new pipes to fit on. Do not stress about making up a brake pipe the same length yet. We are doing a nice neat custom job rather than setting ourselves needless hurdles!
Making new brake pipes involves using one of my favourite tools. My brake pipe flaring tool was about £30 from ebay about 10 years ago. It does a great job every time, flares copper or steel pipe, has very few moving parts to go wrong and you dont need a vise.
Slide the new brake pipe end on first! You feed the new pipe in, finger tighten the 2 10mm bolts, tighten the 16mm bolt at the end. This positions the pipe to be flared. You then tighten the 10mms to clamp the pipe
[img
20181209_130605 by deeelux deeelux , on Flickr
When the pipe is clamped you screw this bit in. This end gives you a male flare. On most Japanese cars the pipe has a female flare.
[img
20181209_130730 by deeelux deeelux , on Flickr
So you unscrew it and screw the other end in, this gives the flared end a female flare
[img
20181209_131324 by deeelux deeelux , on Flickr
Now you can refit it. Feed the pipe roughly in position ensuring it is routed the correct side of suspension components etc. Dont worry about the shape or length. Screw the end into the wheel cylinder etc with your fingers. This can be tricky on a jimny as the pipe does not fit in at right angles to the cylinder. Once its started tighten it up. I'm using a brake pipe spanner but you dont really have to. Remember you are tightning it up to compress the seal on the pipe. You dont want to tighten it up until your arm is shaking!
[img
20181209_131805 by deeelux deeelux , on Flickr
Dont hold the spanner at this angle unless you want to punch the underside of a jimny! When this end is tight shape the pipe and fit the clamps/clips back on as you go. When you get to the other end cut the pipe. Leave a few cms of slack. Your bends are not going to be as sharp as the factory ones so your pipe needs to be a bit longer.
[img
20181209_132448 by deeelux deeelux , on Flickr
Flare the new end on, screw it in. Tweak the position of the pipes as necessary and thats it! Easy!
[img
20181209_143311 by deeelux deeelux , on Flickr
[img
20181209_143352 by deeelux deeelux , on Flickr
09 Dec 2018 16:36 #198799 by Delux
Deluxs guide to replacing your aerial
I done this guide today on my 54 plate convertible but its the same procedure for hardtop and older versions.
First step is to disconnect the old aerial, or whats left of it. If your car has its original aerial you will find there is a small extension lead between the end of th aerial lead and the back of the stereo head unit. Its usually under the dash next to the centre console on the drivers side.
[img
20181209_143949 by deeelux deeelux , on Flickr
Its the fat, black cylinder in the centre of the pic. Cut the cable tie off and give it a pull, aerial lead should unplug. I mention this because someone was asking about reception problems and their aerial was ok. If corrosion is in this plug your radio reception will be rubbish! Anyway, follow it along, this one runs along the under dash bar thru some reusable cable ties. Follow it along until it disappears into the roof pillar to make sure its free all the way along.
[img
20181209_144318 by deeelux deeelux , on Flickr
Its hard to picture, it leads over the top of that black box into the pillar. Easier to feel than show!
Next, tie a bit of string round it. You can tape a bit of wire to it but I prefer string as you can tie it and its harder to accidentally pull off!
[img
20181209_144556 by deeelux deeelux , on Flickr
Now you can unscrew the aerial base and carefully pull it out the pillar. As mine is a convertible the aerial base is on the pillar facing forward. On the hard top the base is kinda above the front corner of the door but the procedure is the same.
[img
20181209_144721 by deeelux deeelux , on Flickr
Keep going, gently until
[img
20181209_144739 by deeelux deeelux , on Flickr
I just pulled a bit off the end of a big ball of string. If you are just using a length of string make sure you have enough length!
Anyway, my aerial (on the right) is off ebay (about £20) and the lead is much longer which makes it easier to refit.
[img
20181209_144907 by deeelux deeelux , on Flickr
Feed the aerial plug in 1st gently pulling the string back thru. Dont pull too hard, some jiggling may be required. You may need to fish the new plug out the hole in the pillar. Once its thru bolt it back on. The one I bought was slightly thicker so I couldnt use the original screws, luckily it was supplied with new ones which were fine.
[img
20181209_145752 by deeelux deeelux , on Flickr
As this aerial has a longer cable it will reach the head unit. I will remove the extension cable and run it straight into the head unit. Just not today as I forgot my radio pins!
17 Dec 2018 21:39 #199122 by Delux
No update this week. Not because I am lazy! Had one of those weekends where you just cant get the matches to light!
Popped in to finish something off at work on Saturday morning, ended up working until 4!
Sunday, attacked the Jimny with an angry expression and a bag of tools. Tried taking the N/S/F hub assembly off to sort the leaky seal/kingpins etc. but got stuck with a spinning track rod end nut. Tried jacking it up but the nut was having none of it! Nothing in the tool bag to cut the nut to bits.
Decided to get stuck into the service instead. Drained the oil, realised I had nothing to take the oil filter off, or take the spark plugs out.
Switched to the timing belt. Removed the fan, radiator, fan belts. Realised I didnt have an 8mm socket with me so stormed off in the huff. Rest of the day was taken up with Tesco, top gear and candy crush. I promise a better update next week!
18 Dec 2018 05:25 #199131 by Lambert
Been there, done that!
Time to create page: 0.226 seconds
