Bob! Daily driver/something to play with!
- eddlane
24 May 2019 19:55 #208892
by eddlane
Replied by eddlane on topic Bob! Daily driver/something to play with!
Evening all.
Been quiet again. Tax man ate my money this time.
Got a new battery, thanks for the tip. Went Yuasa in the end, like a new jimny!!
I also took him to get professionally blasted rust cured and undersealed after not liking the look of the underside when I got under, hopefully he lasts a bit longer now.
Next jobs, I need to do the kingpin bearings and add a shim to try and stop this darn death wobble! I also want to do a 2” lift whilst I’m at it, any tips on kits? It’s for occasional off roading for the mad places I go for work so doesn’t have to be the biggest meanest toughest kit.
Also also also, wheel spacers. I know they increase wheel bearing wear rate but I’m cool with that, any tips? What’s the max mm I can get away with without adding extra arches?
Thanks in advance!
Thanks in advance!
24 May 2019 20:08 #208895
Replied by jackonlyjack on topic Bob! Daily driver/something to play with!
Jimnybits black raptor 2" kit will do you just fine
32mm spacers with 215 wide tyres on standard wheels any bigger tyre will stick past original arch
- eddlane
24 May 2019 20:22 #208896
by eddlane
Ideal thanks I’ll take a look and save some pennies.
- eddlane
24 May 2019 20:37 #208897
by eddlane
www.jimnybits.com/suzuki-4x4-32mm-wheel-spacers-5716.html
Do these spacers look any good or is it worth paying the extra for the black raptor ones but they are only 30mm.
Cheers
Cheers
- eddlane
24 May 2019 20:45 #208898
by eddlane
And when it comes to kingpin bearings, shall I go Suzuki branded or are the SKF ones just as good?
Also what other jobs on the front axle should I be doing whilst I’m doing kingpin bearings and shims?
Cheers
Cheers
- Thank you received: 2001
25 May 2019 06:11 #208908
Replied by Lambert on topic Bob! Daily driver/something to play with!
I would get the king pin bearings from the bigjimny shop, Suzuki bearings at not Suzuki price. The only other thing on the front axle is the caliper slides that are prone to not doing. Sometimes you can resuscitate them and other times they have to be replaced.
