My green laner project
06 Feb 2019 19:57 #202705 by ahtr
Replied by ahtr on topic My green laner project
OlaGB wrote: How about some china lockers? Approx half price of arb`s.
@OlaGB I have had a read of your build and had a look at the Chinese lockers after you fitted them, I was tempted! When I was looking at the China lockers I noticed the e-locker Riccy mentioned.
Riccy wrote: You could be the first in the UK to try an e-locker for a jimny as well...
@Riccy I had seen these, wasn't sure of how well they'd be built and wasn't sure I wanted to be the guinea pig :lol: Got a trip away in a couple of months, when I get back I might give one a go...
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
  • OlaGB
06 Feb 2019 20:40 #202707 by OlaGB
Replied by OlaGB on topic My green laner project
I also read up on e-lockers, but i found alot of people struggling with them.. Do youre research before you buy, as it might be just spesific brands that has issues.
Alot of good videos about it on YT, positive and negative.
07 Feb 2019 08:33 #202721 by Max Headroom
Replied by Max Headroom on topic My green laner project
ahtr - some great photos there - thank you for sharing those!
Where did you get the Denso sensor and how much was it in the end?
The following user(s) said Thank You: ahtr
07 Feb 2019 11:24 #202726 by ahtr
Max Headroom wrote: Where did you get the Denso sensor and how much was it in the end?
Lambda was £61 from sparkplugs.co.uk, cheapest place I could find at the time.
The following user(s) said Thank You: Max Headroom
07 Feb 2019 19:40 #202756 by Max Headroom
Thank you for that. Mine's a 2006 VVT so I need to try and establish the correct part - it may not be the same as the one you needed
07 Feb 2019 21:30 - 07 Feb 2019 21:31 #202768 by ahtr
Max Headroom wrote: Thank you for that. Mine's a 2006 VVT so I need to try and establish the correct part - it may not be the same as the one you needed
Think it might be the same as the non-VVT but would be worth double checking. One in the manifold is Denso DOX-0354. One after the cat in the exhaust is Denso DOX-0350.
Last edit: 07 Feb 2019 21:31 by ahtr.
Time to create page: 16.573 seconds
