Furo's Jimny Build
22 May 2020 13:23 #222666 by jackonlyjack
Replied by jackonlyjack on topic Furo's Jimny Build
Are you using correct coaxial cable and a spliter box for radio
22 May 2020 13:45 #222668 by furo
Replied by furo on topic Furo's Jimny Build
Thanks Jack! Yes I'm using a similar splitter and I bought that exact coaxial cable. A coaxial cable runs from the radio to the splitter, then another coaxial cable runs from the splitter up to the radio mount on the roof (which has a built-in ground). I had hoped to attached the antenna directly to the original radio mount but it didn't fit, so I got another coaxial cable and joined the radio mount to a homemade antenna mount (just some washers and a M6 bolt that the antenna threads onto). So the whole length is coaxial cable apart from the join in the original radio mount.
So far I haven't been able to properly check it with anyone else who has a CB, but one thing that concerns me is there is absolutely no difference in my FM radio quality if I screw the antenna on vs leaving it as just the bolt! I don't know what that means.
22 May 2020 13:47 #222669 by furo
furo wrote:
In this image you can see the bolt in the radio mount, to which I have attached a further length of coaxial cable. The cable runs to a bolt in the roof rack that I screw the antenna onto.
22 May 2020 13:56 - 22 May 2020 14:03 #222670 by jackonlyjack
Sounds to me like you have made a direct short
between the centre core to the braid by going onto a bolt
they need to be separated by this kind of connector
www.thunderpole.co.uk/rf-plugs-connector...rg223-h155-type.html
this is the mount i use
www.thunderpole.co.uk/fixed-body-mounts/...stick-mount-kit.html
Last edit: 22 May 2020 14:03 by jackonlyjack.
The following user(s) said Thank You: furo
23 May 2020 11:54 #222734 by furo
Thanks Jack. I was careful to fold back the braid and used heat-shrink over it, so I don't think it has shorted with the centre core.
If the whole thing is disconnected I only get static on my FM radio. If I connect the cable to the roof rack without an antenna I get reasonable signal. If I add the antenna the signal is unchanged. So is the whole roof rack acting as an aerial? Sorry if these are stupid questions. Do I need to make sure the antenna is isolated from the roofrack?
Time to create page: 0.182 seconds
