Roof switch pod
  • Riccy
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
29 May 2017 09:56 - 29 May 2017 09:57 #181630 by Riccy
Roof switch pod was created by Riccy
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationSo with installing all sorts of extra stuff ive come to the point of needing switches.
Bought a load of these for all the different things:
and made this for them to go into out of 1mm steel sheet:
and pulled the headlining out for a clean and to make brackets on the roof for the pod to attach to:
But then a friend said - what about using that as a mold for vacuum forming?
I can see what he's saying because the metal is fairly heavy, a plastic molded one would be much easier to mount up there. So had a look and found this stuff:
and a video on youtube about how to make a vacuum forming box and heat the plastic in an oven. Looks pretty straightforward, but advice would be appreciated. The mould being steel could be re-used many times also ;-) I think i saw something about vacuum forming that Kiethy was doing for wheel arches?
Riccy.
Last edit: 29 May 2017 09:57 by Riccy. Reason: no video on ebay, should have been youtube.
29 May 2017 10:17 - 29 May 2017 11:23 #181631 by jackonlyjack
Replied by jackonlyjack on topic Roof switch pod
I like bespoke work well done ;)
Yes Keithy built his own vac forming machine
Jack
Last edit: 29 May 2017 11:23 by jackonlyjack.
  • Daniel30
29 May 2017 14:39 #181636 by Daniel30
Replied by Daniel30 on topic Roof switch pod
Yeah turbo keithy is the man to talk to B)
29 May 2017 15:58 #181638 by Keithy
Replied by Keithy on topic Roof switch pod
I saw the metal part and thought vac form.....I see you have too!
I'll be going a different route on the overhead console....bit of storage and cb mount mainly.....one line of switches across.
I built a 4' X 3' belovac style vac former to make the bodykit but I'll be building a smaller one for the 350mm off-cuts I have from making the bodykits.
I'll build it similar to the phlatformer with the heater elements below the sheet and use the vac pump from the big boy.
I quite like the metalwork you've made......you need a tig welder next! :D
I use a cnc router I made a few years back for pattern making......you'll need one of those soon too!
Get it built and pull some skin! the small stuff is I'd say easy.....the larger stuff gets a little tricky.
I use an industrial vac pump weighing 100kg but I think a dyson with the filters removed would do 2mm easy enough.
Don't forget to think outside the box and allow for the thickness of the material and the way it affects radii<posh word for radiusses....
as an aside, the original patterns I made with mdf were ruined by the vac forming company after one pull......I've made 3 bodykits and the patterns are still good as new......bloody vac forming company....£300 for the mdf weeks of machining and £500 for the bodykit made that exercise an expensive one.
  • helijohn
30 May 2017 20:08 #181654 by helijohn
Replied by helijohn on topic Roof switch pod
Great stuff.
  • Riccy
  • Banned
  • Banned
31 May 2017 06:12 #181655 by Riccy
Replied by Riccy on topic Roof switch pod
Thanks everyone for the comments... more progress...
Ive Glued it to a bit of plywood which has rounded corners and dimples for fixing screws,
This should make an edge that can be trimmed easily to the roof profile and provide fixing points.
Just need the sheets to arrive to start playing! (and to make the boxes)
Kiethy - my welding is really not up to much im using a gasless mini-mig at the moment, which is messy to say the least. maybe its time to invest in something better! Tig looks pretty difficult to get right.
For a vac i have an old 1800w bosch vaccum cleaner that has loads of suck once the filters are taken out, and goes straight onto full power when switched on (unlike my newer henry which starts at half power and has to be persuaded into full go mode). Im hoping this will be enough. i was planning to heat the plastic in the oven (good job i live on my own!).
Time to create page: 0.269 seconds
