samurai axles onto jimny
  • steved
17 Oct 2016 22:16 #173675 by steved
samurai axles onto jimny was created by steved
some info please on fitting samurai axles to jimny also 2 questions,do you have to reposition front panhard rod as the track rod is on front of axle, also do i need to modify gearbox x member where the front prop passes over as the samurai front diff is not high pinion so prop will drop lower at full suspension drop thanks
Time to create page: 0.261 seconds
