What to do?
  • zukiara
16 Sep 2015 09:36 #152050 by zukiara
Replied by zukiara on topic What to do?
No Mate, Lift isn't on, but I need some info from you, before proceeding?
On your Duo of 2" GV metal strut spacers what was the measurements between all top three fixing bolts?
Secondly would your 15mm spacers fit my rear springs?
They are 113mm at widest point and 86mm at the narrowest closing end?
Cheers
Eeeeeeeee
  • X8GGY
16 Sep 2015 11:29 #152056 by X8GGY
Replied by X8GGY on topic What to do?
Just been out to measure the strut head bolts in the engine bay...
They are on a PCD of approx 122mm, or measured from the centre of each bolt to the next they are approx 105mm centre to centre...
I don't stock them any more as they were poor sellers...
JimnyBits have a similar one but machined rather that two-steel-plates...
15mm spring spacers are 110mm OD and 63mm ID ;)
Hope all that helps?...
Daveeee
  • zukiara
17 Sep 2015 10:39 #152120 by zukiara
Cheers Dave,
Strut spacers arnt going to work,
15mm spacers on the back will,
but all on hold till next month and Ive finished moving.
Itll get there
  • zukiara
20 Sep 2015 10:52 #152285 by zukiara
  • X8GGY
20 Sep 2015 18:09 #152296 by X8GGY
If you're going to buy one Eeee... www.snorkels.es are a lot cheaper (copies)
  • zukiara
20 Sep 2015 19:00 - 20 Sep 2015 19:01 #152305 by zukiara
Need to see what may fit first, thinking of going to Nene overland to see what they have on the shelf, to have a ganders.
Plus emailed your www.snorkels.es first and they said they couldn't help me???
Last edit: 20 Sep 2015 19:01 by zukiara.
