Placek's 33" Jimny
19 Mar 2015 17:42 #140939 by kirkynut
Replied by kirkynut on topic Placek's 33" Jimny
Can you get TG shafts for the Vitara rear axle? Are they needed with a locker in the Vitara rear axle or are the standard Vitara rear shafts bomb proof?
I know you can get them for Sammy rear axles.
  • X8GGY
19 Mar 2015 17:48 #140941 by X8GGY
Replied by X8GGY on topic Placek's 33" Jimny
Twenty years abusing Vitaras and I've only ever turned the splined ends off two shafts where they enter the diff (with the help of a Centerforce clutch, crawler box and a rear LSD)... if that helps
  • Placek
19 Mar 2015 18:52 #140947 by Placek
Replied by Placek on topic Placek's 33" Jimny
kirkynut wrote: Can you get TG shafts for the Vitara rear axle? Are they needed with a locker in the Vitara rear axle or are the standard Vitara rear shafts bomb proof?
Rear Vitara axle is bombproof ;) I have TG shafts and joints in front samurai axle.
  • Nicks_Jim
19 Mar 2015 21:32 #140966 by Nicks_Jim
Replied by Nicks_Jim on topic Placek's 33" Jimny
MysticRich wrote: Have you moved your front axle forward ?
It's a job on my to do list as I'm running 32" tyres on the jimny axle with Robb storr shafts ect and my tyres still foul on the body and I have 4" springs on the front with a 2" body lift on what cab I have left after the tray back and that's after I have cut everything away possible.
Interested in the used of vitara rear axle and could be a good option.
Would the jimny diff fit in an vitara axle to keep gearing same ??
Hi MysticRich, just reading ur post about ur tyres fouling on ur body with 32" tyres. i have the same sort of setup as u.i have 32" insa turbo tyres no body lift, and a 4.5" D&G suspension setup, but i did have D&G radius arms front and rear. i had to cut away the inner arch foot well side and angle the small box section under the head lights. but now i have changed the front D&G radius to kap suzuki ones which are about 12mm longer. which totally misses the body.hope this helps, Nick
  • Placek
20 Mar 2015 17:33 #141001 by Placek
Yes, 16cm.
  • jimnydms
24 Mar 2015 17:29 #141265 by jimnydms
Replied by jimnydms on topic Placek's 33" Jimny
do you know how the ORA mk1 radius arms compare for size ? i have the same tyres/setup and same problem
thanks
Time to create page: 0.298 seconds
