Placek's 33" Jimny
02 Feb 2016 10:43 #161700
by Busta
Replied by Busta on topic Placek's 33" Jimny
400kg heavier than standard! No wonder she's a bit unstable.
- Thank you received: 1998
02 Feb 2016 20:17 #161742
Replied by Lambert on topic Placek's 33" Jimny
I'd be more interested in the centre of gravity than the actual weight if it were mine what with the cage and the radiator up so high and then the body having relatively low resistance to roll with the big flexible suspension. Ok there's some low down mass provided by the weight of the tyres and axle strengthening but even so I would still be looking at getting as much weight as low as I could, as it trying falling over on every second corner would be quite tedious.
Good luck with the shake down though, I'm sure that you will find suitable solutions for some of it's little idiosyncrasies.
- GraphicX
03 Feb 2016 01:37 #161763
by GraphicX
is that with or without you in the car ? the GVM of a jimny is only 1420kg so you're already in the red either way
Replied by GraphicX on topic Placek's 33" Jimny
Placek wrote: I have wighted my Jimny: 3262 lbs (1480kg) fully tanked and ready to drive. Mass distribution to axles: 53% front, 47% rear.
- Placek
05 Feb 2016 09:32 #161893
by Placek
Replied by Placek on topic Placek's 33" Jimny
The suspension is a bit too soft, but flex does the job in rough terrain very well. That was the first test, I'm sure I'll improve few things in the future but for now I'd like to test the car in competition conditions and see how it'll do.
I'd like to avoid the half-measures because in the long term they are cost inefficient so probably in a year or two I will swap suzuki axles to toyota and go for coilover shocks, but that's expensive and after this build I am broke
and need some time before I will think about big investments.
So now I will have maximum fun from what I have but will keep all suggestions in mind for the future improvements.
And of course few photos
Command center:
New emblem:
And my favourite sticker
Command center:
New emblem:
- Placek
07 Mar 2016 08:18 - 07 Mar 2016 08:22 #163440
by Placek
Last edit: 07 Mar 2016 08:22 by Placek. Reason: typo
- Placek
21 Mar 2016 17:27 #164159
by Placek
Time to create page: 0.247 seconds
