Placek's 33" Jimny
- Placek
01 Jan 2016 20:30 - 01 Jan 2016 20:33 #159511
by Placek
Replied by Placek on topic Placek's 33" Jimny
Last edit: 01 Jan 2016 20:33 by Placek.
- Statey
05 Jan 2016 22:56 #159857
by Statey
Replied by Statey on topic Placek's 33" Jimny
words cant express how much i appreciated the work going into this build!
- Placek
12 Jan 2016 20:27 #160243
by Placek
We started to fit all the goodies to the dashboard.
To the left from the steering wheel are air compressor and front locker switches. Down from them are backup front and rear winch controller plugs in case the main switches at the dashboard failed.
In the center down from switches are two 150-1000A power swithes connected parallely which makes them together one 300-2000A switch (smart me
Left clock shows the water temp near engine, right one near cooler, middle clock is the rpm meter, small square is voltmeter, big square is tripmeter (which has a repeater at passenger side). The red indicator goes on when oil pressure gets too low, green when the cooler fans turn automatically on, blue when 12V water pump turns automatically on. White is blank
Upper row from the left: ignition, led bar, left working led, right working led, rear working leds, manual water pump, manual fans 2nd speed.
Lower row: starter. front winch, rear winch, heater, inside leds, front handbrake valve, rear handbrake valve.
Above all there's a CB radio,
And thats how the exhaust pipe will go through the chassis
And a short clip what happens when I turn the main power switch and ignition on:
- suzukisam
12 Jan 2016 21:10 #160246
by suzukisam
Replied by suzukisam on topic Placek's 33" Jimny
This is one of the best build threads by far . You seem to put the hours in and it surely shows ,Im almost certain it will be one of the best jimnys out there . I wouldn't know where to start with all that wiring
Look forward to seeing this finished and hope u will be more than happy with it once finished
- NineCherries
14 Jan 2016 20:28 #160368
by NineCherries
Replied by NineCherries on topic Placek's 33" Jimny
The video is cool. It does remind me of the DeLorean from back to the future though. Lol. I was half expecting dates to appear in the display.
It looks great and I enjoy catching up with your build when I'm online. Keep the updates coming.
14 Jan 2016 20:49 #160370
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Placek's 33" Jimny
1.21 gigawatts!!!
Grey pick up Jimny
Time to create page: 0.215 seconds
