  • S200KYS
10 Jun 2016 19:35 #168317 by S200KYS
mc_nebula wrote: I've recently had the same issues with my Jimny. I believe it was caused by running a Lockrite. I ripped off one mount and widened most of the mounts on the axle. It also ate my rear prop too.
I had a spare axle already, so swapped it over and have not re-fitted the lockrite. I'm running a standard diff now.
I'm running an ARB air locker, so I only turn it on when I think I need it... :S
The topic has been locked.
10 Jun 2016 19:42 #168318 by Me and my Jimny
Interesting reading about the lockers, so am I right in thinking that the extra grip can put additional strain on the other parts which have then failed ?
Enjoyed the blog Dave, hope the rebuild goes well so we can get another soon
  • supergaz
10 Jun 2016 20:31 #168321 by supergaz
Replied by supergaz on topic Dave's "S200KYS" Jimny 'laner Build...
Me and my Jimny wrote: Interesting reading about the lockers, so am I right in thinking that the extra grip can put additional strain on the other parts which have then failed ?
Lockrights are very hard on shafts, I switched to ARB airlockers to give the shafts an easier life but an open diff will always be better for the shafts but far less capable off road.
10 Jun 2016 21:11 #168327 by mlines
I run an arb locker and my mounts ripped off.
Sent from my Nexus 6P using Tapatalk
  • S200KYS
12 Jun 2016 16:49 - 12 Jun 2016 16:52 #168413 by S200KYS
Replied by S200KYS on topic Re:Dave's "S200KYS" Jimny 'laner Build...
Sorted today...
Had a lie in 'til 9:30 B) usually up at 5:30, so that was nice :laugh: Walked the dogs with the wife for once, and then we had a cooked breakfast, so it was a leisurely 11:30 when I entered the man cave... Perfect! :lol:
Refitted the Zanfi rear Panhard Bracket to the replacement axle casing...
Got the axle reconnected to the radius arms by jacking it up to the extended bump stops to push it into place ;)
And then fitted the new rear ProComp shocks whilst the axle was up on the bumps to check that they weren't too long when compressed, as I feared that was how the AVOs got bent... but no, a good inch and a half before the shocks would top out...?
(That's the new insert sleeve in the bottom of the ProComp shocks... it's a 10mm internal instead of a 12mm, as I use 12 grade long bolts through the bottom shock mounts)
And then with the springs at rest, to check the shocks aren't too long when fully extended, and a similar amount left...
New bolts, spring washers and "strawberry jam" :laugh:
Ready to lift the air locking diff back in...
All back together...
And a replacement prop to fit...
Sorted...
All ready for the Lake District Weekend on the 25th and 26th... B)
Last edit: 12 Jun 2016 16:52 by S200KYS.
  • OllieNZ
12 Jun 2016 16:57 #168414 by OllieNZ
Replied by OllieNZ on topic Re:Dave's "S200KYS" Jimny 'laner Build...
Nice,
Not going to get rockwatt to do a beefed up case for you?
Time to create page: 0.276 seconds
