- S200KYS
08 Dec 2014 23:51 - 09 Dec 2014 00:33 #131903
by S200KYS
Replied by S200KYS on topic Dave's (Bits4Vits) Jimny 'laner Build...
Jimny loses it's virginity... HENRYD! :blink:
From Brett's camera ^^
From my dash GoPro ^^
Chuffed!
Chuffed!
Last edit: 09 Dec 2014 00:33 by S200KYS.
The topic has been locked.
- S200KYS
21 Dec 2014 16:44 - 21 Dec 2014 16:51 #132957
by S200KYS
Finished off the breathers today! Thanks to reading a post on here about fitting breathers... it inspired me to have another look at the gearbox breather...
Lying on my back in the garage I could spot the breather poking out in the transmission tunnel... Strange, as I'd always read that getting to the gearbox breather was a real chore?
Closeup... there's just a little bit of rubber pipe on the breather tube and then a small plastic cap on it...
So I reached up and pulled the cap off, and used that as a reference to order a reducer - 8mm internal pipe to 6mm plastic tube to match what is supplied in Martin's / BigJimny's excellent breather kit...
The reducer fitted perfectly into the end of the existing breather rubber tube, and the tube supplied with Martin's / BigJimny's breather kit fitted in perfectly...
And the other end of the tube plugs into the manifold blog I added to Martin's / BigJimny's breather kit (as my Rockwatt Rocklobster transfer box already had a 10mm elbow connected to it when I got it)
You may remember, the right hand 10mm black tube goes back to the transfer box, the 3 smaller 8mm tubes pointing down go to the front and rear axles, and now the gearbox breather, whilst the left one heads up to the snorkel's head -
And is neatly held to the genuine Safari snorkel with a couple of plastic P-Clips on the mounting bolts...
Breathers Complete!
Breathers Complete!
Last edit: 21 Dec 2014 16:51 by S200KYS.
- S200KYS
21 Dec 2014 18:34 #132967
by S200KYS
Another job today... fix the "death wobble"... last time out greenlaning it was happening at all sorts of speeds, and lots of times... frustrating! So I vowed today to find out what was wrong! Armed with a list of things to check, and it what order, I soon discovered -
... that the panhard rod mounting holes have been elongated. I could hear metal on metal rattling last trip out, but I assumed the bushes had gone... I didn't think it would be this!
So I drilled some 6mm plate, to make a couple of new mounting plates...
And then thought I'd need one for the axle end too -
So I made a third one...
I then bolted them in place and then...
Welded them in place...
And then went for a test-drive........................... ALL SORTED!
- S200KYS
21 Dec 2014 18:40 #132968
by S200KYS
Next job...
Recently, when pulling off in first, or when the engine is under-load offroading, I've heard a "fluttering" and suspected that the rear engine / gearbox mount had gone...
So, I ordered one from this very store - www.bigjimny.com/store/index.php?_a=product&product_id=215
Here it is -
And, when I took the old one out...
I was indeed right, the original one had delaminated, and the "fluttering" noise was the engine and gearbox moving on the mount when under load...
Jack under the gearbox, unbolt the old mount, pop in the new one...
And then tighten it all up -
Another test-drive, and we're all ready for another days 'laning this coming Sunday... the now traditional Christmas / New Year trip with Brett's Sausage Rolls and my wife's Mincemeat Roulades
I feel a blog coming on?
Here it is -
- S200KYS
30 Dec 2014 01:57 - 30 Dec 2014 01:59 #133581
by S200KYS
And here is that blog... another excellent days' 'laning with "our little group" -
www.bits4vits.co.uk/store/winching-and-w.../12/14/blog_294.html
Enjoy!
Here's a compilation of photos of my Jimny from the day
And my favourite photos from the day -
Taken with a "selfie-stick" !!! :woohoo:
Coming off the Wayfarer, and the valley below is full of mist...
Another, to the right of the photo before...
Enjoy!
Last edit: 30 Dec 2014 01:59 by S200KYS.
30 Dec 2014 12:22 #133618
by Mescort
G16B, Doug Thorley Header, Trail-Gear 6,5:1 Transfer, Front 28 Degree CV propShaft, Rockwatt crawler box kit, Zanfi 2" springs, Zanfi 10° + 10mm Front Radius arm, Caster Correction Bushes rear, Adjustable Panhard, Bilstein 5100 Shocks, Dotz dakar 15x7, goodyear duratrac 235x75x15, warn M6000
Replied by Mescort on topic Dave's (Bits4Vits) Jimny 'laner Build...
like your blogs
The following user(s) said Thank You: S200KYS
Time to create page: 0.623 seconds
