  • Bits4Vits
15 Aug 2014 16:34 #122120 by Bits4Vits
Replied by Bits4Vits on topic Re:Dave's (Bits4Vits) Jimny 'laner Build...
Bits4Vits wrote: I'd personally use 6mm ...
I did say personally... I'm no expert, just a home modder, and I chose to make mine out of 6mm plate...
You can use whatever you see fit :)
The main thing is having fun building and driving our little trucklets! B)
The topic has been locked.
  • Bits4Vits
15 Aug 2014 16:41 - 15 Aug 2014 16:43 #122121 by Bits4Vits
The ORA front winch bumper is made of thinner sheet, not sure what off the top of my head, but is double-skinned where the winch mounts on the reverse of it -
B)
Last edit: 15 Aug 2014 16:43 by Bits4Vits.
15 Aug 2014 17:14 #122122 by funkyjimny
My ARB winch bumper is made up of different thicknesses, from memory I think it's 5mm for the area around the winch and 3mm for the sides and tube bull bar.
Gary
  • Bits4Vits
23 Aug 2014 10:30 #122577 by Bits4Vits
Not had enough spare time to touch the Jimny... wife and daughters are in Crete for two weeks, back on the 31st, so work will resume the week after that... currently running the shop, post office and Bits4Vits, and looking after our two 7 month old Labradors... I was going to work on the Jimny tomorrow, but after a lie-in and being summonsed to my Mum's for a sunday roast they'll be no time spannering ;)
I will be having a quick measure and a sketch for the roofrack-come-treeslider bars that the ORA are going to bend up for me though! B)
  • Bits4Vits
02 Sep 2014 17:44 #123231 by Bits4Vits
Right! Family are now back from sunning themselves in Crete for two weeks, so it's time to crack on again...
Drilled the chassis rails today and then took the slightly modified (to fit round a rear winch) ORA bumper to the powdercoaters, as a phone call earlier in the day had revealed my bumper would tip their silver waiting list. So I took it in to Rhyl today, and should get a phone call Thursday to go pick it up, so that should be fitted and wired up on Sunday...
Need to get a hurry on as we're exploring Shropshire's 'lanes on the 21st...! B)
"Day off" tomorrow (the middle bit anyway) so I need to start stripping the front of the old Vitara "Zukhini" for it's winch and Dyneema rope and fairlead... and behind it... a steel diff with an LSD in it, that's getting sent off to Rockwatt the "God of Gearing" to get blended into a Jimny front diff from our communal spares (so thanks to Brett and Gary for that), I'll thn swap it with mine and return mine to the communal spares pile ;)
More soon! ;)
  • Bits4Vits
08 Sep 2014 21:39 - 08 Sep 2014 21:46 #123657 by Bits4Vits
There's loads more photos on my blog, but here's a summary for you ;)
Rear ORA bumper back, wired and remounted!
Front and rear now match nicely, and flow nicely along the lines of the trucklet...
Super-bright 6-LED array reversing light / work light / (Gary's "twat" light!)
You can now see where the winch is getting to sit... soon-ish! ;)
Meanwhile, the Zukhini Vitara disappeared off to Vitara Heaven over the wall onto the scrappy's hiab flatbed...!
Switch panel if fully wired now too...
Left to right -
T-Max split charge system
Front 18-LED spot bar
Yellow isolator aircraft switch for:
Rear Winch (not fitted quite yet...soon!) rocker switch
Front Winch rocker switch
Rear reversing / worklight blue aricraft switch
Internal rear hardtop section 9-LED worklight
Twin horns red round push-to-make switch
Flash 18-LED spot bar blue push-to-make switch
Reversing alarm silence on/off white switch
ARB rear airlocker switch
ARB compressor switch
(Cigarette lighter swapped for iPad charging USB port!)
The rear reverse light / reversing alarm silencer / rear winch controls have all been wired using a run of 7-core trailer wire, which leaves 2 cores spare for the future too. (white reversing alarm silence (it just turns off the reversing alarms earth!), yellow rear reversing spot, blue/green/brown for the winch solenoid, and red and black currently spare - this will serve as a reminder for me when I lose the scrap of paper I've written it on!!!) ;)
Last edit: 08 Sep 2014 21:46 by Bits4Vits.
Time to create page: 0.281 seconds
