PUG 1900 DIESEL CONVERSION
- greenjimny
13 Mar 2014 20:25 #108486
by greenjimny
PUG 1900 DIESEL CONVERSION was created by greenjimny
been fitting one of these into my jimny for the last week or so
not been taking pics much just been getting it done lol
pleased to say its defo taking shape now with only a few things left on the list of mods
engine is mounted , wired , plumbed , exhausted
clutch is sorted gearstick sorted
need to sort the rear box mount , propshaft , new fuel line , and a few bit of wiring for ancilliaries
1900 DW8 , pilot box
13 Mar 2014 20:43 #108492
by j999pre
Grey pick up Jimny
Replied by j999pre on topic PUG 1900 DIESEL CONVERSION
Cool, how easy was it? Does it shut lower with that extra weight in?
Grey pick up Jimny
- greenjimny
13 Mar 2014 21:22 #108500
by greenjimny
Replied by greenjimny on topic PUG 1900 DIESEL CONVERSION
forgot to measure with the 1600 in it lol , think it dropped 3" ... no engine - engine box fitted so prob
not much of a difference at all
- chris2010
04 Apr 2014 18:57 #111250
by chris2010
Replied by chris2010 on topic PUG 1900 DIESEL CONVERSION
This is a conversion iv had the intentions of starting .
Engine box is out of mine . And have the engine and box from a 1.9 td 306 with pilot box ready to go in,
How did you get on , adapting the clutch operating mechanisms from hydraulic to cable ?
Or did you use hydraulic through out,?
Some pics of this would be handy if you have any
Good luck with it all
Also how did levers locate in the car through the original hole?
- greenjimny
10 Apr 2014 17:09 #111827
by greenjimny
hi mate was watching your post closely but with no new updates i went it alone lol
hydraulic clutch , its taking a bit of getting used to cos of the short travel on the pedal but works fine
the stick came through the tunnel slightly further forward than the original one but this will depend on where you mount your engine of course !
i dare say that if its mounted extremely tight to the bulkhead it would pretty much be in the same place as standard but ive mounted mine forward quite a bit the drawback of this is that the bonnet was hitting the inlet manifold but a trip to the scrapyard and five mins with a cutting disc soon mounted a scoop
the upside is that ive got loads of room around it to work on it and plenty space for a turbo lump when one turns up cheep cheep
- chris2010
12 Apr 2014 08:44 #111969
by chris2010
unfortunatly iv had my younger brothers car stuck in my garage for the last 4 months so , only just starting,
what clutch master cylinder did you use ?
i know from experience with rangers, if you put an adjusterable rod between pedal and master cylinder you should be able to adjust where on the pedal it bites.
what radiator did you use in front of yours ?
was there much clearance between sump and front axle?
last question i promise lol , did you use standard ldv engine mounts ?
cant wait to get started in the next week or so.
Time to create page: 0.162 seconds
