Where to Start
  • barnes
03 Sep 2013 08:05 #82000 by barnes
Replied by barnes on topic Where to Start
Little Jim wrote: Let me see, Carmarthen is 30-40 miles away (down the road really) and St Clears is another ten from there. I live in North Ceredigion. Little Jim is a daily hack to get me to the church on time and to get to the field for the shoot or up the miles of lane etc. Do it all but not too extreme
Same here but im the other way port talbot, you want a set of all terrains and a 2" lift just to keep it simple
  • Little Jim
10 Sep 2013 17:21 #82771 by Little Jim
Replied by Little Jim on topic Where to Start
You hear a lot about them tipping over. A mate who has one say it is all bo%%ocks, but I was wondering about the lift will this make this tendency worse, better or make no difference?
Cheers
10 Sep 2013 17:47 - 10 Sep 2013 17:49 #82776 by Busta
Replied by Busta on topic Where to Start
A lift will make it less stable, is expensive and causes other complications. You only need a lift if you want to fit bigger tyres, and you'll only need them if you are going out of your way to try to get stuck. You can also expect to see the good mpg go out of the window with bigger tyres and a lift.
A standard Jimny on knobbly tyres is an incredibly capable machine. As Tadpole says, see how you get on with it how it is before getting carried away with mods!
Last edit: 10 Sep 2013 17:49 by Busta.
  • tommyguns
24 Sep 2013 15:20 #84216 by tommyguns
Replied by tommyguns on topic Where to Start
im in the same boat as you, would love it if i can get 40mpg out of her!
im looking into getting some AT's (would love muds but depends on fuel consumption effects so need to do lots more reading into it), then snorkel and wheel spacers.
Good luck, look forward to seeing how you get on!
  • Zee Zee Top
22 Oct 2013 03:01 #87443 by Zee Zee Top
Replied by Zee Zee Top on topic Where to Start
Little Jim wrote: OK Guys and Gals,
As you will have read I have recently arrived with a 2006 Jimny. I have reshod her with some YOKO AT rubber to replace the perishing OE Bridgestones. At first refill I have we managed 40mpg so I am pretty happy with that. She is off to be waxoiled tomorrow. I don't want to lose the economy, but I would like to make her as capable as she can be within that restriction for the wilds of west Wales.
So the question is where do I start and how far do I take it?
Many thanks
Are the tyres Geolander AT/S?
If so what do you think of them?
  • PascalASR
22 Oct 2013 16:16 #87504 by PascalASR
Replied by PascalASR on topic Where to Start
Hey Jim!
I would keep just simple if it is also your ride for every day. Just some better tires and max 40mm suspension lift. If want to put a bigger tires then also 40mm on the body, pretty cheap and dont need to do NOTHING except just make your selfs inserts of teflon or nylon. I did them in teflon.
Cheers!
P.S. Put some pics of your ride!
Time to create page: 0.203 seconds
