winches
- Basketcase
15 Jul 2012 15:51 #44193
by Basketcase
winches was created by Basketcase
Hey guys im looking/thinking about getting a winch fitted to the front of my jimny but i dont know what size winch id need iv been told i need one that can pull about 2500kg but is that rolling stock or what im really confused. i found a winch on ebay it says its 2000lb straight pulling and 6000lb rolling stock would one this size be suitable for occasional off road use or would i need to get a bigger one?like for example a 4000lb straight pulling?
- TomDK
15 Jul 2012 16:20 #44197
by TomDK
Replied by TomDK on topic Re: winches
You'll need a 6000 lbs winch as minimum.
Preferably a 9500 lbs winch, like Superwinch Talon 9.5 or Goodwinch TDS 9.5c
www.dborc.co.uk/goodwinch/
- Smoggy
15 Jul 2012 17:31 - 15 Jul 2012 21:45 #44200
by Smoggy
Replied by Smoggy on topic Re: winches
Yeah I second that. I've recently got myself a Goodwinch 9.5. Better to be over-engineered I say, rather than stuck up to your axles in mud in the middle of nowhere.
Last edit: 15 Jul 2012 21:45 by Smoggy.
- reaper
15 Jul 2012 19:10 #44208
by reaper
Replied by reaper on topic Re: winches
No eBay APP ID and/or Cert ID defined in Kunena configurationI got one of these its a cheepi but been very good , they also do a sythetic rope version
Recently saw the same winch fitted to a snatch landrover so carnt be to bad
- vitara_mad
15 Jul 2012 20:02 #44219
by vitara_mad
Replied by vitara_mad on topic Re: winches
don't waste your money on a 2000lbs winch it won't pull the skin off a rice pudding :laugh:
i would recomend at least 8000lbs as a min
- X-Eng Simon
16 Jul 2012 00:14 #44248
by X-Eng Simon
Replied by X-Eng Simon on topic Re: winches
Although your Jimny may be light - and you would think that a winch powerful enough to lift the vehicle would be enough, it's not.
The reason is that if you are dragging a vehicle though mud, the amount of pull required is proportional to the amount of mud you are pushing in front of you. Chances are this will be as much as a Land Rover - thus, you need a similar rating to a winch on a Land Rover.
9500Lb is about right for most circumstances with most vehicles - but even with that, there will be situations where you need more and have to double-line it with a snatch block (pulley).
Si
Si
Time to create page: 0.351 seconds
