eaton m45+jimny hells connfetti
- The Erk
23 Jan 2012 19:58 #31682
by The Erk
eaton m45+jimny hells connfetti was created by The Erk
Well as the name suggests guess what ive been working on
work is still in progress and i thought i would float the project hear to get some ideas and feedback.
At the moment im purely dealing with engine mechanicals and gas flow/ pressure management, albeit slowly.
A rough outline of the overall outlook in case you were wondering,
An engine capable of running 31 inch tyres on road with near stock gearing
Custom cut low range (to follow) inside sj413 tcase
bigger brakes inside 16 inch rims,
big cheesy grin
already on a 3 inch lift.
big cheesy grin
- The Erk
23 Jan 2012 20:18 #31686
by The Erk
Replied by The Erk on topic Re: eaton m45+jimny hells connfetti
so far ive pulled the engine out, pulled off the manifolds, pulled off the head and sump, honed the bore out by 1 thou, regapped the rings to tollerate more heat, put the block back together and mounted the blower, just need to pull it all apart to pain the mounts.
the plan is to boost it to aprox 8lbs at 5000rpm, when i find my bits of paper again I'l post how i propose to do this and what blower overdrive ratio i'l be using.
- The Erk
23 Jan 2012 20:19 #31687
by The Erk
and no thed is complete without piccys
[attachment:1]C:\fakepath\2012-01-14_17-03-48_496.jpg[/attachment]
[attachment:2]C:\fakepath\freshly honed ish.jpg[/attachment]
- Bigchridy
23 Jan 2012 21:03 #31693
by Bigchridy
Replied by Bigchridy on topic Re: eaton m45+jimny hells connfetti
What engine is it? G13B or M13A?
Cant wait to see some pic's!
How are you going to deal with the engine management system?
Chris
Chris
- the erk
07 Oct 2020 12:57 #228891
by the erk
Replied by the erk on topic Re: eaton m45+jimny hells connfetti
Well after a brief pause, (8 years) and a selection of mixed results, it seams that it is time to revive this old girl and her thead.
- the erk
07 Oct 2020 12:58 #228892
by the erk
piccys of her last outing, 5 years ago, running the m13 engine and mini eaton m45
Time to create page: 0.094 seconds
