Bmw
30 Nov 2016 16:27 #175114
Bmw was created by Daniel30
Now I know it's not a jimny but I also know that there is some clever people on this site so I was wondering if any one had any ideas why my dash lights and brake lights were stuck on today on my 325 Ci BMW the key fob does not work now so I unlocked the car with the key, it started on the button everything normal then when I switched it off the same lights came back on again, I have now disconnected the battery
Any help would be appreciated
30 Nov 2016 17:58 #175119
Replied by Daniel30 on topic Bmw
Think I have sorted it now :silly:
- fozzie
30 Nov 2016 18:20 #175121
by fozzie
Replied by fozzie on topic Bmw
What was it??
30 Nov 2016 18:43 #175123
Well
I have been on the net for a while and a BMW forum and apparently one of the causes is moisture in/behind the instrument cluster, I don't use the BM much and there was a large build up on the inside over the last couple of days were it has been mild during the day and -4 during the night, so the result is leave the battery off for a good few hours and it should sort itself out also you can pull fuse 43 apparently and it does the same job but have been advised to get it plugged in and have a look to see if there is any other fault codes, I probably just need to use it more
01 Dec 2016 11:11 #175145
No!! :laugh:
They are broken though every time i go to use the indicators the windscreen wipers come on ?? then when i go to use the windscreen wipers the indicators come on :silly: :silly: :silly:
Don't know why its fine on the jimny :woohoo: :woohoo: :woohoo:
Time to create page: 2.215 seconds
