Tyre sidewall damage
20 Jun 2016 17:42 #168924 by mlines
Tyre sidewall damage was created by mlines
My son has low profile tyres on alloys on his Swift.
The tyres have a moulded "rim protector" around the circumferance of the wheel. It is a raised rubber section designed to help protect the alloy wheel.
He was forced into the kerb by an oncoming driver this morning and clipped the kerb. This has lifted a 1cm section of the tyre protector ring off the sidewall of the tyre. It is still attached but you can pass a flat screwdiver behind the rubber and out the other side (of the raised surface) a bit like a skin piercing.
As the side wall of the tyre is fine, its just a surface moulding that has lifted, I assume this is fine to continue in use/MOT test?
  • 1066Boy
20 Jun 2016 18:03 #168926 by 1066Boy
Replied by 1066Boy on topic Tyre sidewall damage
Should be fine to use and mot. :)
If in doubt about mot, its superglue time. ;)
20 Jun 2016 18:20 #168929 by jackonlyjack
  • Nicks_Jim
20 Jun 2016 19:04 #168932 by Nicks_Jim
Replied by Nicks_Jim on topic Tyre sidewall damage
mlines wrote: My son has low profile tyres on alloys on his Swift.
super glue works fine. used it many of times to get me out of trouble
20 Jun 2016 19:36 #168934 by kirkynut
Replied by kirkynut on topic Tyre sidewall damage
I've gone to use cars at work and found this in the past and taken the car to the workshop for them to give it the once over and they said it was fine. It's done its job effectively!
As long as there's no bulge etc, but you know what you're looking at Martin!
  • gilburton
20 Jun 2016 19:39 - 20 Jun 2016 19:42 #168935 by gilburton
Replied by gilburton on topic Tyre sidewall damage
As long as there are no cords showing it's fine.
Assuming all the tyres are the same size you could swap it to the other side and put it on the rear so that the "flap" is facing backwords so shouldn't catch on anything??
Last edit: 20 Jun 2016 19:42 by gilburton.
