Floods
- Basketcase
26 Dec 2015 18:21 - 26 Dec 2015 18:22 #159143
by Basketcase
Floods was created by Basketcase
What's the legality of driving through water on the road where it's flooded with a road closed sign? There is no barrier only a closed sign further up and a standard car stuck to the side upto it's headlights. I know I can definitely get through it as I've been through a lot deeper flowing rivers than this puddle before.
Last edit: 26 Dec 2015 18:22 by Basketcase. Reason: Spelling error
26 Dec 2015 18:43 #159144
by Rhinoman
Good question, its unlikely there will be a TRO so the sign may not have any legal standing. If there are any properties nearby you should avoid causing a bow wave that will go through them.
- Basketcase
26 Dec 2015 18:57 #159145
by Basketcase
Replied by Basketcase on topic Floods
It's a smallish stretch of road over a small(usually anyway) canal. The Canal has flooded the road the nearest buildings are on a built up part so they can't flood. Might go have a look tomorrow
or later if it keeps raining
- minibbb
26 Dec 2015 20:50 #159151
by minibbb
Replied by minibbb on topic Re:Floods
Not that we have flooding down here but what's the advice for driving through water? Am I right in thinking you need to keep the revs up to stop water going up the exhaust?
26 Dec 2015 21:39 #159153
The issue is flow. Flowing water pressure on the side of a vehicle. There is a Ford near us that becomes dangerous at about 18 inches. Takes the Jimny's rear wheels sideways. After flow then floating is the next issue if you find still water that's deep.
Sent from my Nexus 5 using Tapatalk
The following user(s) said Thank You: minibbb
- Basketcase
26 Dec 2015 22:51 #159168
by Basketcase
Replied by Basketcase on topic Re:Floods
Keep the revs up but not excessive and follow the bow wave, don't go in too hot or you'll lose it if you keep to the bow wave it will help drag you through it
Time to create page: 0.168 seconds
