Halfords Dog Lotty
  • Daniel30
16 Aug 2015 20:55 #149943 by Daniel30
Replied by Daniel30 on topic Halfords Dog Lotty
Wow!!! :)
  • gusthegorilla
17 Aug 2015 19:40 #149990 by gusthegorilla
Replied by gusthegorilla on topic Halfords Dog Lotty
Halford wrote: :laugh: very good Daniel, from little acorns ............... and from little Jimnys' :woohoo:
Gus re: the "double pots" the added height of the inner pot gives more rootspace whilst the outer pot has holes in the base and it's into this space the water/feed goes once a week without wetting the plant stem and leaves (reducing possible disease and blight) , normal water is drawn from the base reservoir via capilliary fabric into the underside of the grow bags. This means the toms have a steady water suppy and can go up to 3 days without the need to re-water.
So even the toms have had a body lift
Hate to ask this, Hal, but any chance of a diagram...I know you love doing them?
G ;)
17 Aug 2015 20:07 - 17 Aug 2015 20:08 #150002 by Halford
Replied by Halford on topic Halfords Dog Lotty
simples
even better to pinch some one elses pics ;)
Last edit: 17 Aug 2015 20:08 by Halford.
  • gusthegorilla
17 Aug 2015 20:16 #150005 by gusthegorilla
Aaahh...as you say...simples :whistle:
So by the look of it, the 'double pot' bit is purchased as a one-piece, and sits in the grow bag with some extra compost in it. Yes??
But where does the orange bit with the capilliaries go? Inside the growbag, two to each green part???
17 Aug 2015 20:42 #150016 by Halford
here it is
purchased pot sits in growbag which sits on gizzmo with capillary matting and water reservoir
if you're after some then make sure you get the darker green pots, whilst the lighter green pots have the benefit of x3 hole for locating canes, their drain holes are too small and require drilling out to enlarge, also the under water reservoir trays also have locators to accept support canes so the former are not necessary.
The following user(s) said Thank You: gusthegorilla
  • gusthegorilla
17 Aug 2015 20:59 #150021 by gusthegorilla
Now I have it and it's my fault, I should have looked more closely at your first picture!!
Simple but brilliant, thanks Hal...is it next spring yet???
Time to create page: 0.204 seconds
