question for the mechanics
- markyp2000
- Visitor
06 Mar 2013 21:03 #64796
by markyp2000
Replied by markyp2000 on topic question for the machanics
Yer it would drip between the sump and gear box it may have a hole there to allow fluids to come out you may find i only leaks when driving ie pressing the pedle down also just check the pedle and carpet to see if it has fluid on it if so it the clutch master cylinder leaking and check the back of the wheels to see if the brakes are leaking
- nicho
- Visitor
06 Mar 2013 21:11 - 06 Mar 2013 21:23 #64798
by nicho
Replied by nicho on topic question for the machanics
found this
Clutch release bearing (full concentric slave cylinder release bearing unit)
is this what you were asking. dose that mean it is all one bit.if the master is leeking and its fluid was low would that make it the cluch slip. i mean dose the fluid engage the cluch or disengage the cluch or dose it do both. thank you very very very much for the help.
Last edit: 06 Mar 2013 21:23 by nicho.
- markyp2000
- Visitor
06 Mar 2013 21:43 #64801
by markyp2000
Yer thats the part fluid disengages and the pressure plate in the clutch helps the pedle come up fluid on the pedle wouldnt make it slip but would make sence for the fluid lose have you sat next to her while driving to see if she rests her foot on the clutch as a little bit of presure on the pedel is a lot on the clutch
- nicho
- Visitor
07 Mar 2013 18:01 #64858
by nicho
well cant see any leaks anywere but the fluid has droped as toped it up 3 4 week ago and light comes on when cars tilted so it aint lost much, im thinking of geting it bled n toped up n see what happens no leaks arond brakes eather. took it fo a spin n i couldt make it slip at all, could be like you sead driping from inside, just had cambelt done n injector seals done to, its a 03 plate only 30 qwid to tax n had 70 mpg from it on a trip and cheep to insure but shes bored of it now n thinking of selling n getin a JIMNY.
- nicho
- Visitor
08 Mar 2013 13:27 #64974
by nicho
topped up fluid and went for another drive tried to make it slip n couldnt do it,ony when absolutely ragin it foot to floor in to high gear reves go up a bit comperd to acceleration,could this just be the dmf doing its job n protecting the grearbox.
- Dave cc
- Visitor
08 Mar 2013 18:42 #64995
by Dave cc
Replied by Dave cc on topic question for the machanics
Dual mass flywheel doesnt slip to protect the gearbox if it slips its buggered its there to take up the snatch between the engine and box and apparently do something to do with harmonic something or what ever :laugh:
TBH most are a load of shite they break judder and garages wont fit you a clutch without fitting a new flywheel normally so they can then rob you twice.
If it is buggered then there are people who supply solid flywheels and conventional clutches as a conversion money well spent in my book
Time to create page: 0.144 seconds
