Website Migration
10 Nov 2024 19:29 - 10 Nov 2024 19:29 #258250 by mlines
Website Migration was created by mlines
The website has been growing old underneath the hatches. The OS and its attendant PHP library etc. has been kept up to date up to the point earlier this year when it went out of support. This means it is now no longer supported and is more than 3 generations behind in some areas.
I have been building a new server on the full set of latest libraries and it is just about ready to go.
As some point later this week the change over will occur.  You should hopefully only see a slight change in layout and colours. The main module I cannot move is "Tapatalk" as this is so old (and doesnt work properly anyway) so will be lost in the move.
You may see a "This site has been turned off" message, this will be because your cache has not refreshed. Your best bet is to wait (cache sorts itself out). However with some ISPs this can take a long time (particularly on mobile platforms). You can try a browser refresh using key strokes such as F5 or ALT-F5.    You may also like to make a note of this URL: test.bigjimny.com which has been in use by me for testing for a month or so and therefore should have propagated to the far ends of the Internet, However you should try the proper URL www.bigjimny.com to use the real website as soon as the cache clears. Of course if you use the test URL above before the move occurs and actually post on the site your posts will be lost as the last action of the transfer will be to synchronise the databases across which will erase anything on the new site
Last edit: 10 Nov 2024 19:29 by mlines.
The following user(s) said Thank You: Lambert, gv42, Gadget, Soeley, Motacilla
10 Nov 2024 20:01 #258251 by Lambert
Replied by Lambert on topic Website Migration
All I got from that is that it's old and we're getting a new one. Thank you for your efforts!
The following user(s) said Thank You: Gadget
10 Nov 2024 21:44 #258252 by DrRobin
Replied by DrRobin on topic Website Migration
We all normally have no idea how much effort it takes to keep a website like this running, thanks for all of the hard work in the background and we look forward to the new site.
Robin
11 Nov 2024 11:31 #258259 by yakuza
Replied by yakuza on topic Website Migration
13 Nov 2024 13:09 #258288 by mlines
Replied by mlines on topic Re:Website Migration
Delayed due to database issue
Sent from my ThinkPhone by motorola using Tapatalk
The following user(s) said Thank You: Lambert, yakuza, gv42, Soeley
15 Nov 2024 19:54 #258337 by mlines
I think i have found the issue. I took a data snapshot of this site and built the new site based on this. once the new site is running I then tried to update the new site with any new posts or newusers that appeared on the site during my build process, This over-write destroys the new website,
I think I can only do it by "freezing" and switching off the old site and doing the build in one go which would mean an outage of a few days,
Time to create page: 0.193 seconds
