Test for embedded picture problem
05 Jan 2021 06:07 - 05 Jan 2021 06:09 #231507
Test for embedded picture problem was created by mlines
Test to discover Dave's embedded picture issue - please ignore
Bit of text
More text
Even more text
Dragged and dropped image
Post edit added image
Bit of text
More text
Even more text
Last edit: 05 Jan 2021 06:09 by mlines.
05 Jan 2021 06:13 #231510
Replied by mlines on topic Test for embedded picture problem
- X8GGY
05 Jan 2021 12:24 - 05 Jan 2021 12:28 #231522
Replied by X8GGY on topic Test for embedded picture problem
Test by Dave
No, still doesn't work -
Second image, the screen shot manually IMG tagged in by adding the [ IMG ] code...
See the image says it's inserted ("In message") but no code is added?
I also get a problem if I "quote" someone else's post, the quote appears, but then I can't add to the post in the (new) editor...?
I'm using Google Chrome on my desktop PC... if that helps?
Last edit: 05 Jan 2021 12:28 by X8GGY.
05 Jan 2021 12:30 - 05 Jan 2021 12:34 #231523
Note: There seems to be a new, little red arrows that appears.hard over on the right side of the screen at the bottom
that adds in blank lines for you to type in.
Test for quoting!X8GGY wrote: Test by Dave
Last edit: 05 Jan 2021 12:34 by mlines.
05 Jan 2021 12:33 #231524
Dave,
For the image issue can you list the exact steps you are following as I am using the same browser etc and not seeing the issue.
e.g.
1. Click on reply
2. Click on "Attachments".......etc.etc. etc.
Thanks
e.g.
1. Click on reply
Thanks
- X8GGY
05 Jan 2021 13:53 - 05 Jan 2021 13:54 #231525
Ok, thanks Martin...
Clicked -
Reply
Typed the above
Click "Attachments"
"+Add Files"
(Selection image - Google Chrome Version screendump)
Can see image below -
(Martin1 attached image)
Click the "Insert" button
(Martin2 attached image)
And although it says in the now green button "In Message", it isn't.. (in the editor)
Clicked -
Reply
Typed the above
Click "Attachments"
"+Add Files"
Last edit: 05 Jan 2021 13:54 by X8GGY.
Time to create page: 0.841 seconds
