Wiki problems?
7 years 11 months ago - 7 years 11 months ago #198877
by Delux
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
Wiki problems? was created by Delux
Tried adding the guides I wrote in my current build guide to the 'How to' section on the Jimnywiki section. I thought some people may find them useful given certain recent subjects in the forum.
Followed the help section on setting up a new page, that worked!
Copied and pasted the guide and clicked 'preview'. That worked!
Clicked to publish my page and received an error message stating my session had timed out.
'Sorry! We could not process your edit due to a loss of session data.
You might have been logged out. Please verify that you're still logged in and try again. If it still does not work, try logging out and logging back in, and check that your browser allows cookies from this site. '
I followed the recommendations,
I checked my browser allows cookies from the site. It does!
I checked I was logged in. I was!
I logged out then back in again.
Still didnt work!
Am I doing something embarrassingly wrong?
Still didnt work!
Last edit: 7 years 11 months ago by Delux.
7 years 11 months ago #198881
Replied by mlines on topic Wiki problems?
Hi
First of all, thank you so much for attempting to add to the Wiki, it is very much appreciated.
This website has ongoing issues with sessions and session timeouts. Its a balance between convenience and security and when combined with some bugs in the operation it is a nightmare.
In the Wiki, you are offered two versions of editor. A basic text editor that seems stable but requires knowledge of Wiki mark-up language to make it look nice. The text editor is the most stable. There is also a "WYSIWYG" editor which is much prettier to use but suffers much more from session instability.
WHat makes it worse is switching between editors as they interfere with each other.
The simplest way might be to write the plain text off-line and then paste it into the basic editor and get it to save it. Then you can pretty the layout up later.
If you want to retry the editors then you could delete current cookies from this site and then only use one editor (do not switch between them).
An alternative is to create your content in a document and send to Bosanek (a user on this site). He is the principal contributor to this site and will be able to upload it for you.
The following user(s) said Thank You: Delux
7 years 10 months ago - 7 years 10 months ago #199193
by Bosanek
Replied by Bosanek on topic Wiki problems?
I am having the exact same issues on the wiki for the last half a year, but I have just been lazy to report ...
Sometimes the wiki does not accept an edit when I try to save it.
It says the exact same message that Delux reported.
It appears that I can usually save a first edit in a particular day, but any subsequent edit in the same day usually fails in this manner. I have also found out that a selective clearance of all browser cookies for the web site www.bigjimny.com (and then logging back in in the wiki) solves it ... for the first edit after that. The 2nd edit after that fails again, and I have to repeat the same procedure all over.
This issue, apart from being frustrating, "deflects" / dissuades new potential Wiki contributors from becoming actual contributors.
P.S.: I never use the fancy editor, always the plain textual one, and I regularly encounter this issue.
Last edit: 7 years 10 months ago by Bosanek.
7 years 10 months ago #199391
by Delux
Replied by Delux on topic Wiki problems?
IT WORKED! NEARLY.
Sitting bored, waiting for family to descend, mess my house watching 'Bruces price is right'. Thought I'd have a go. Using the fancy editor I copied the script for my 'fitting an aerial' guide and hit 'submit'. Worked perfectly first time!
Motivated by this success I tried with my 'How to do brake pipes' guide and.....
same old time out problem! Will try again later.
7 years 10 months ago #199393
by Bosanek
I have just checked your first wiki edit (aerial fitting guide).
Not bad at all for a first edit ever!
But it will need some correction of the article name and proper categorization. I can do it for you, just let me know when you are finished editing the aerial fitting article so that our edits do not collide.
It appears that you do not know how to create a new wiki article from scratch (you actually edited a master category article and wrote your guide directly in it). Do not worry, I will fix that.
To help you avoid the same issue next time, I created an empty article for your next guide:
www.bigjimny.com/mediawiki/index.php?tit...nd_hoses_replacement
Freely edit that one.
7 years 10 months ago #199404
by Delux
Thanks Bosanek. Not really sure what I have to do to edit it!
If you have the time, sort it then I can add the changes to the brake pipe one.
I have a few more guides on the way so now is probably the best time to iron out any problems. Have even made a sign for the workshop to remind me to take pics, LOL!
Time to create page: 0.098 seconds
