Rough Country N2.0 Shocks - now in stock!
  • reaper
14 May 2013 16:46 #70679 by reaper
Replied by reaper on topic Rough Country N2.0 Shocks - now in stock!
Thankyou
What about the new versions are they the same ?
  • Sponnie
14 May 2013 17:54 #70684 by Sponnie
Replied by Sponnie on topic Re: Rough Country N2.0 Shocks - now in stock!
mlines wrote: I think that these are basically the same as previous Rough Country models. There are couple of small upgrade points, the main one being the gas pressure.
I have not used these yet as they are new but they are going to go onto "BigJimny" in the next few weeks (Yes, BigJimny is coming back to life!).
Therefore if you feel your current set up is over damped I would not be convinced that these are the answer.
The rear of a Jimny has always been an issue as its so light in standard form. I current have Pro comp ES9000 on the front and Pro comp ES3000 on the rear. However I have a full cage, metal rear bumper and large winch battery in the boot.
Thanks Martin. Ill leave it then lol
Sent from my GT-I9300 using Tapatalk 2
14 May 2013 20:06 #70714 by mlines
I do not have the specs for the new ones but as they are the replacements they should be similar.
I could cut the restraining straps on a set (probably at risk of life and limb) to see what they extend to I suppose.
  • reaper
14 May 2013 20:19 #70722 by reaper
Ahh good point thanks again martin
When can we order ?
14 May 2013 20:51 #70727 by mlines
Now? They are in stock
The following user(s) said Thank You: reaper
  • reaper
16 May 2013 17:50 #70867 by reaper
Just remembered to measure my rears and at static the shocks you have are perfect at there mid point of 19.12 inch B)
