Rough Country N2.0 Shocks - now in stock!
12 May 2013 15:24 - 12 May 2013 15:25 #70543
Rough Country N2.0 Shocks - now in stock! was created by mlines
Rough Country have upgraded their shock range and changed them to the N2.0 Product line.
These are now the default shock absorber supplied in the shop.
Here is what Rough Country have to say:
Who says your daily driver and your weekend warrior can't be the same vehicle? Introducing The N2.0 Shock absorber: Engineered by Rough Country's Research and Development Team specifically for both on and off-road use. N2.0 shocks are nitrogen charged at 200 PSI to prevent foaming and offer a longer lifespan. Incorporating "Velocity Sensitive Valving" technology, these shocks utilize a 10-stage variable valving process that helps facilitate resistance valving incorporated in the shock according to piston rod speed. This allows for a super smooth highway ride and outstanding control in rugged off road situations from the same shock, without turning any knobs or shock removal for re-adjustment. Each shock is tested and custom tuned for its specific vehicle application. It's Chromed Hardened 9/16" Piston Rod and massive 1 3/8" Bore allow for fluid movement while providing the type of heavy duty durability needed in off-road situations.
Specifications:
10-Stage Variable Valving
200 psi Nitrogen Charged
Massive 1 3/8" Bore
Spring Loaded Piston Rod Seal
Military Spec. Fluid Rated To –50° C
Rubber bushings for better absorption
Limited Lifetime Warranty
Silver powder coat finish
I have a few 9000 series left in stock (white ones) and these can be ordered for £42 each, these are equivalent to Pro-Comp ES9000 series. Please contact me if interested in these old stock items.
Specifications:
Massive 1 3/8" Bore
Last edit: 12 May 2013 15:25 by mlines.
- Sponnie
12 May 2013 21:27 #70578
by Sponnie
Replied by Sponnie on topic Rough Country N2.0 Shocks - now in stock!
I went to knock on the door of Milners this weekend as my current Rough Currenty shocks are over damped on the rear. But they were out. Will these be better (softer or more controlled) than the white ones?
When my damper brackets broke the ride was super soft (and super bouncy) so i know the ride can be improved to a point.
Thanks
Thanks
13 May 2013 08:44 - 13 May 2013 08:46 #70600
Replied by mlines on topic Rough Country N2.0 Shocks - now in stock!
I think that these are basically the same as previous Rough Country models. There are couple of small upgrade points, the main one being the gas pressure.
I have not used these yet as they are new but they are going to go onto "BigJimny" in the next few weeks (Yes, BigJimny is coming back to life!).
Therefore if you feel your current set up is over damped I would not be convinced that these are the answer.
The rear of a Jimny has always been an issue as its so light in standard form. I current have Pro comp ES9000 on the front and Pro comp ES3000 on the rear. However I have a full cage, metal rear bumper and large winch battery in the boot.
Last edit: 13 May 2013 08:46 by mlines.
- reaper
13 May 2013 17:02 #70627
by reaper
Replied by reaper on topic Rough Country N2.0 Shocks - now in stock!
Hi martin
Could you give the fully extended length of the +3-4.5 ones please
I have pro comp +4 on and they are very short imo so after a new set-up
- mudman
13 May 2013 19:16 #70634
by mudman
Replied by mudman on topic Rough Country N2.0 Shocks - now in stock!
i have these on mine and they have transformed it so much smoother over evry bump
14 May 2013 06:07 #70657
The white 9149 Rears on offer - 23.82 inches 14.42 inches
The white 9155 Fronts on offer - 22.04 inches 13.89 inches
The following user(s) said Thank You: reaper
Time to create page: 0.195 seconds
