rear shock bolts
  • nicho
19 Oct 2012 19:08 #50826 by nicho
rear shock bolts was created by nicho
hi just wondering when youl have some in stock ta..
19 Oct 2012 19:25 #50838 by mlines
Replied by mlines on topic rear shock bolts
Umm - now!
Didn't realise the shop appeared to not know I had some!
  • nicho
20 Oct 2012 08:42 #50870 by nicho
Replied by nicho on topic rear shock bolts
ta ill get some ordered then
  • nicho
23 Oct 2012 17:37 #51099 by nicho
ta for the bolts. just a quick one should the top shock bolts screw all the way in, they both seem to screw in the same leaving about 8mm gap, im thinking they are screwing in up to were the old bolts were and i need to tap the hole right through so the bolts can come through the other side.thanks for any info.
  • thorpee
24 Oct 2012 09:00 #51141 by thorpee
Replied by thorpee on topic rear shock bolts
Have you got the original washer and/or spring washer on the top rear bolt?
  • nicho
24 Oct 2012 10:58 - 24 Oct 2012 17:36 #51154 by nicho
No i aint,will put some on, there will still be a gap the bolts only going in less than 3/4 of the way in the threds i just thought the hole would have been tapped right through,dose any one know the pitch of the thread is it 1 or 1.5,ta, thinking of just running a tap down them.
Last edit: 24 Oct 2012 17:36 by nicho.
Time to create page: 0.168 seconds
