Jimny steering tie rod end
- panosd
08 Jun 2012 13:57 #41972
by panosd
Jimny steering tie rod end was created by panosd
Hello Martin. Can you tell me if you have the track rod end?
I mean this one
Uploaded with ImageShack.us
My car is left side drive.
How much does it costs? Postage for GR 62055 ?
Thanks a lot.
I mean this one
Thanks a lot.
08 Jun 2012 23:31 #42040
by kirkynut
Replied by kirkynut on topic Re: Jimny steering tie rod end
I have just replaced mine with parts from the Big Jimny Shop and the steering box is in the same place and that steering arm is the same as on Right Hand Drive.
I think the part you want is the one in the Big Jimny Shop with the part number FTR5341 but it might be best to wait for Martin to confirm this before ordering.
If replacing one, you might wish to consider doing them all, as if one is worn, the others can't be far behind them!
- panosd
09 Jun 2012 08:05 #42052
by panosd
Replied by panosd on topic Re: Jimny steering tie rod end
Thanks a lot kirkynut.
I will wait for the confirmation from martin. I have made a checking to all of them and the rear ones of the
steering bar behind the axle are still fine.
My car is left hand drive so the steering wheel bar is from the ather side. I will take a picture to see
10 Jun 2012 18:59 #42139
Replied by mlines on topic Re: Jimny steering tie rod end
Yes, they are in my shop. Although Kirkynut has told you which one it should be , you should really check the thread on the end as we have found that some cars are fitted with the rod the other way around. A simple check is to find which way the lock nut turns.
martin
martin
- panosd
11 Jun 2012 13:14 - 11 Jun 2012 13:15 #42167
by panosd
Martin i found the suzuki code for this, ''48810-81a00''
so now can you teel me which one is that i need?
Last edit: 11 Jun 2012 13:15 by panosd.
14 Jun 2012 07:46 - 14 Jun 2012 07:48 #42331
by kirkynut
Assuming your tie rod is the right way round you need FTR5342. This has a normal thread - clockwise to tighten, anti clockwise to loosen, so you can check by undoing it.
To get a price on the item and postage, put the item in the shopping cart with your address in the shop and it will give you a price all included. I think it still does this for overseas customers but not beingone I'm not sure!
Last edit: 14 Jun 2012 07:48 by kirkynut.
Time to create page: 0.411 seconds
