SJ hub spacers.
- Sam_
22 May 2012 09:37 #40931
by Sam_
SJ hub spacers. was created by Sam_
Hi Martin,
Just thought I'd let you know I got the spacers you sent me at the beginning of last week and fitted them the Saturday just gone.
Thanks for sending them out so quickly much appreciated, but I thought I'd let you know they didn't fit straight away. I had to open out the holes to 9mm before I could get them to fit.
Just wondering whether they fitted before galvanizing and then the thickness of the coat is causing the holes not to line up?
Just thought you should know!
22 May 2012 10:35 #40938
Replied by mlines on topic Re: SJ hub spacers.
Thanks, I had only checked the new batch visually against an existing one. It sounds as if there is a very slight tolerance difference.
- Sam_
22 May 2012 13:35 #40944
by Sam_
Replied by Sam_ on topic Re: SJ hub spacers.
Yeah I think its very close, maybe next batch have the holes drilled slightly bigger? As being only a spacer it shouldn't matter if the holes are slightly bigger than the original?
Did have me baffled for a little while though!
17 Jun 2012 07:28 #42483
by robs5230
standard jimny - for now
Replied by robs5230 on topic Re: SJ hub spacers.
mine came yesterday and no issues with the holes. thanks
