Rear shock brackets
  • Jamie
29 Nov 2009 10:42 #1550 by Jamie
Replied by Jamie on topic Re:Rear shock brackets
Thanks Martin,
Do you need my address??
I will send you these back also i forgot
to send you that hub!! i will try and get
that to you soon!!
Jamie
29 Nov 2009 13:52 #1552 by mlines
Replied by mlines on topic Re:Rear shock brackets
Jamie,
I still have your address.
Do not send your old ones back, they dont fit anything (unless Gary has made his set fit the front???) and you will need the bolts anyway.
Also I have now done all my experimenting on hubs now so no need for the spare hubs.
Thanks
29 Nov 2009 20:53 - 29 Nov 2009 20:57 #1559 by funkyjimny
Replied by funkyjimny on topic Re:Rear shock brackets
Unfortunatly not done any experimenting on the front shock mounts yet, work (and greenlaning!)keeps getting in the way. I'm getting the shock mount welded back on the axle on tuesday and I'll get my mate to have a peek see what he thinks but its probably a christmas job now - i finish on the 18th so should have plenty of time to sort them out then. I'm probably going to bolt and then weld the rear brackets onto the front axle shock mount so that the lower front shock bolt is rotated through 90 degrees and doesnt either destroy the bush or rip the shock mount off the axle when articulating.
Gary
Last edit: 29 Nov 2009 20:57 by funkyjimny.
Time to create page: 0.415 seconds
