Rear shock brackets
12 Nov 2009 12:24 #1457 by mlines
Rear shock brackets was created by mlines
WHERE HAVE THESE GONE????
We had a production issue with the last batch which meant they are not a good fit. This is being corrected and a new batch is "on its way" - watch this space.
I cannot tell which batch anyone may have been sent. If you have found that the clearance between the bottom of the shock and the bracket results in the shock fouling the bracket then please contact me.
The first batch did not suffer from this issue, it was a production error in the second batch.
27 Nov 2009 17:56 #1535 by mlines
Replied by mlines on topic Re:Rear shock brackets
They are back!!
New and improved (extra space to cope with "Old Man Emu" shocks)
  • Baz2236
27 Nov 2009 19:14 #1536 by Baz2236
Replied by Baz2236 on topic Re:Rear shock brackets
Don't suppose it comes with another long bolt does it as mine fell off and is some where around the fens some where.
27 Nov 2009 20:07 - 27 Nov 2009 20:12 #1537 by mlines
Baz,
No sorry, they don't come with the mounting bolt.
However they are supposed to help stop the bolts unwinding, I don't think you already had them fitted dod you?
Last edit: 27 Nov 2009 20:12 by mlines.
  • Jamie
28 Nov 2009 06:46 #1538 by Jamie
Replied by Jamie on topic Re:Rear shock brackets
Martin,
I think mine are a duff set as i've been trying to find
a knocking for week's now finally narrowed it down to the shock mount
after reading your post!!
Jamie
28 Nov 2009 08:46 #1539 by mlines
Jamie,
No problem, I will send you a replacement set
Time to create page: 0.211 seconds
