Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
Lil Red - SJ restoration - Ready for Welding
WhatsApp-Image-2023-02-15-at-13.24.38
After a lull in work its nearly time to start work on putting it back together. The welder came down to view and in discussions wanted some more sand blasting to be done before welding could commence.
Winchfield have a small sandblaster and a very large sandblaster. The large one is used for really heavy duty cleaning but has to be used outside to avoid filling the workshop with dust.
  4411 Hits
Tags:
Lil Red - SJ restoration - The Rust!!
Processed-WhatsApp-Image-2022-12-09-at-12.46.586
Here is a gallery of some close up details on the rust. Winchfield Engineering have been cleaning out each rust spot back to bare metal ready for preparation.
  4923 Hits
Tags:
Lil Red - SJ restoration - Moving on to the body tub
Winchfield Engineering have moved on to starting work on the body tub.
We always knew this was the bad spot as it had some visible rust on the outside, however it can be a bit of a shock as to how bad a "good" car can be.
Here on the drivers side rear we can see the panels that create the rear of the arch have trapped water etc and quietly corroded inside.
  4670 Hits
Tags:
Another SJ Build - Sam's Yellow SJ - An update
Sam has sent in an update on the progress of his SJ. Many thanks Sam!
These SJ restoration projects are proving popular at the moment, if you have some work in progress why not send in the details to show them on this website?
As you can see, the body was stripped of all major components and then removed from the chassis.
In Sam's case this was to assist in a planned upgrade from the 4 speed gearbox to a 5 speed along with a general rebuild of the transmission.
  4912 Hits
Tags:
Lil Red - SJ restoration - Panel work progressing
SJ-rebuid-77
Winchfield Engineering have sent over this update showing the progress on the panels.
The process is the same on all the panels.
They are inspected for corrosion and any corrosion spots are sandblasted clean to remove all the rust.
Here, on the tail gate, you can see where the corrosion has been cleaned away from the mounting holes where a small amount of surface rust existed.
  4788 Hits
Tags:
