BigJimnyMeet 2024
× Tell us about your Jimny and post some pictures! Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Steves Jimny Adventurer
  • JimnyUser
  • Visitor
  • Visitor
27 May 2016 20:05 #167607 by JimnyUser
Replied by JimnyUser on topic Steves Jimny Adventurer
Hi furo, it was around 300 euros with the shipping from Italy
27 May 2016 20:32 #167608 by furo
Replied by furo on topic Steves Jimny Adventurer
Thank you very much!
  • Sutcliffe
  • Visitor
  • Visitor
30 May 2016 10:42 #167708 by Sutcliffe
Replied by Sutcliffe on topic Steves Jimny Adventurer
What are your steelies and what size tyres do you have on mate? Torn between some black 15x7 with off set -30 and same as yours with no offset just ET0 as can't find white ones with a minus offset that are 15x7 other than 15x8, cheers
  • JimnyUser
  • Visitor
  • Visitor
30 May 2016 11:42 #167711 by JimnyUser
Sutcliffe wrote: What are your steelies and what size tyres do you have on mate? Torn between some black 15x7 with off set -30 and same as yours with no offset just ET0 as can't find white ones with a minus offset that are 15x7 other than 15x8, cheers
Hi, the wheels are Tuff Torque ET0 and the tyres are Cooper Discoverer ATS which are on for the summer, I'll be putting some Insa's on the original alloys for winter I think.
  • JimnyUser
  • Visitor
  • Visitor
30 May 2016 19:27 #167723 by JimnyUser
Kingpins, kingpin bearings, shaft oil seals, hub seals changed both sides and fitted new slider, bolts and boots to the nearside caliper. Treated the knuckles and tie bars to a coat of hammerite while they were off too. The steering wobble is much improved but still present a little bit in the same speed range but I'm going to get the front to wheels checked for balancing just to rule that out as they are big old heavy wheels and I can't be 100% certain 4x4 tyres balanced them correctly.
Next job is to get the diff filler plug off so I can change the diff oil, decided after a chisel and centre punch didn't work to order a specific 10mm wrench for the job so fingers crossed that does the trick.
  • Daniel30
  • Visitor
  • Visitor
30 May 2016 20:34 #167727 by Daniel30
Replied by Daniel30 on topic Steves Jimny Adventurer
Looking really good well done :)
  • JimnyUser
  • Visitor
  • Visitor
30 May 2016 21:25 #167733 by JimnyUser
Forgot to say sprayed some plastidip on the freewheel hubs to smarten them up a bit :) and thanks to Dave @ Bits4Vits I now have nice new allen bolts holding them on.
  • Sutcliffe
  • Visitor
  • Visitor
02 Jun 2016 11:54 #167853 by Sutcliffe
What does plastidip do? Has that got rid of rust etc from hubs?
  • JimnyUser
  • Visitor
  • Visitor
02 Jun 2016 12:02 #167855 by JimnyUser
Its a rubberised spray paint, you literally can peel it off and spray it a different colour if you don't like it.
  • Sutcliffe
  • Visitor
  • Visitor
02 Jun 2016 12:27 #167856 by Sutcliffe
Have you bought new brake discs and hubs or is that the plastidip?
  • JimnyUser
  • Visitor
  • Visitor
02 Jun 2016 12:47 #167858 by JimnyUser
yes new discs the plastidip is just on the hubs to smarten them up a bit as they were a bit scratched
  • JimnyUser
  • Visitor
  • Visitor
06 Jun 2016 16:03 #168089 by JimnyUser
This weekend I changed the front dif oil and fitted a new filler and drain plug and then fitted 2 Saris bike fork mounts to the roof rack.
After fitting the dog guard I was left with a spare grab handle which came in handy as a door handle on the shed I've just fiished building...
Powered by Kunena Forum
