Gaz's reasonably priced jimny..
- Thank you received: 360
yes it's a very simple swap
to an Jimny engine ninja master
your words are forever implanted in my mind
"just floor it and you'll be fine" (mud driving advice when grounded) you were right
- gaz3359
- Visitor
Its an easy job i suppose if you know what your doing could be tricky for some.
I learnt that the gently gently approach doesnt really work in some cases as you know it worked momentum is the key.
- Allen
- Visitor
Does the gear box jus bolt straight on to engine no hassle, same shape as the old engine????
- gaz3359
- Visitor
- RichiesJimny
- Visitor
- gaz3359
- Visitor
- RichiesJimny
- Visitor
gaz3359 wrote: Yea i did rich its quite close to the mount but a slight tweak with the grinder and its fine
Yeah I thought when I fitted mine there would be enough room, have you had a drive yet then.
- gaz3359
- Visitor
Yes mate ive used it today and brought it home from the garage its sweet as a nut and drives so much better,should have been a factory option.
Picture of the filter rich
- gaz3359
- Visitor
- Tadpole
- Visitor
- gaz3359
- Visitor
Tadpole wrote: It seems to fit a treat Gaz, you sure you changed it over .....................
Couple of people have said that me dad couldnt even tell anything had been done under the bonnet,but yes deffo been changed lol its been a warm week and doing this had me sweating buckets especially as the garage i work in is like a giant tin oven......
- Smoggy
- Visitor
