BigJimnyMeet 2024
Halfords Dog-Taxi
- Thank you received: 360
13 Dec 2015 22:26 - 13 Dec 2015 23:02 #158464
by Halford
little update .............
Measured from top of wheel arch to road (tyres inflated on level ground)
could really feel the the improvement and now it just feels as it should
not sure why it's needed as springs sitting correctly and still new
originally NS-Front 85.0 cm OS-Front 83.5 cm NS-Rear 85.5 cm OS-Rear 84.0 cm | after fitting 15mm OS-Front spacer NS-Front 85.0 cm OS-Front 85.0 cm NS-Rear 85.5 cm OS-Rear 85.0 cm |
Last edit: 13 Dec 2015 23:02 by Halford.
- darthloachie
- Visitor
14 Dec 2015 00:54 #158471
by darthloachie
Replied by darthloachie on topic Halfords Dog-Taxi
Looking good
- Visitor
14 Dec 2015 06:36 #158475
Replied by Daniel30 on topic Halfords Dog-Taxi
It's seems a bit strange that it was leaning but I'm glad it was an easy fix
18 Feb 2016 11:50 - 18 Feb 2016 11:52 #162618
by Halford
haven't done much to the Jimny recently,
so just had to do something
bought these
really happy with the clock ( (from CPC if interested )
bought these
Last edit: 18 Feb 2016 11:52 by Halford.
26 Mar 2016 08:24 - 26 Mar 2016 08:26 #164378
by Halford
A steering damper fitted ........
For a few years now I'd been thinking of getting a steering damper, but the general populace conveyed the opinion that there wasn't much to be gained in fitting a steering damper to a mainly road based Jimny, hence, it kept slipping back on my to-do-list as the Bank of Jimny isn't a bottomless pit
So I've finally taken the plunge and ordered a chassis mounted kit from Jimnybits
I was well impressed with the solid quality of the fitting kit and after a visit by "Gaz in his reasonably priced Rover" (his Jimny is up for sale ) .... on went the damper
It has transformed the ON-ROAD stability and ride of the Jimny
The steering slackness / lightness / vagueness has gone, don't get me wrong it doesn't make steering hard work, it now feels like a normal cars' steering does, corners are smooth and controlled, straight lines are straight, road surfaces are softer, no more pothole or uneven surface crashy-ness - you really do have to try one to comprehend the difference - and it's not masking any faults on my truck as it's pretty well sorted.
So am I impressed - hell yeah - if you've been sitting on the fence wondering whether to get a steering damper - do it it's well worth it.
Last edit: 26 Mar 2016 08:26 by Halford.
- jim
- Visitor
26 Mar 2016 10:25 #164384
by jim
Replied by jim on topic Halfords Dog-Taxi
Excellent addition Halford. As you say it does remove the vagueness and it just calms it down on bad road surfaces.
I bet your jimny feels amazing to drive on the road with wider wheels, firmer suspension and the damper.
- gaz3359
- Visitor
26 Mar 2016 11:10 #164385
by gaz3359
Replied by gaz3359 on topic Halfords Dog-Taxi
Good stuff hal !
- Visitor
26 Mar 2016 11:18 #164386
Yeah totally agree Halford it was the first mod I done
After having my jimny for about two days !!
- Visitor
30 Mar 2016 17:06 #164654
Shiney!!!!!!!!!!!!
Where did you get It from Halford ? that's on my to do list does it feel good quality ish?
30 Mar 2016 18:15 #164658
by Halford
Just from the local motor factors, complete with a fitting kit, new bolts and crush joints.
Had to use the old crush joints (roughed them up) as the new ones were slightly bigger, may have fit with a bit of work.
The old hot exhaust was popped off and into a vice so the lamba sensor nut slackened easier
Needed a flame on the hanger for it to bend and fit properly,
£120 fitted (£80 - £90 parts) maybe slightly cheaper on tinterBay, but need to get right one and decent quality
Easy job but well worth £30 to have a big lad do it on a ramp with heat to hand, thanks Gaz
- Visitor
30 Mar 2016 18:21 #164659
Not bad thanks Halford
Time to create page: 0.162 seconds
