Halfords Dog-Taxi
- gaz3359
- Visitor
- jim
- Visitor
Halford wrote: with the old ones you can squash the corners of metal plates together slightly, compressing the rubber (with its cracks and minor splits) , bit like a squidgy mallow biscuit.
with the new ones there's practically no give at all.
now I am not adentistspanner monkey, but it feels to me that this minor increase in rigidity had a major increase in car rigidity, driving on the road the car feel much tighter and more responsive, to try and explain the feeling it's like it used to go around a roundabout like a bus, lethargically yet controlled, whereas now it goes around like a mini - point and shoot, much easier to get the back end out
also re; the rear engine (gearbox) mount - the stick doesn't jump about so much and gear selection is easier as before, infrequently I'd miss a gear, but I'd put that down to the body lift and stick realignement, but it wasn't
- Thank you received: 360
made a 2nd attempt at making a sun visor strip, but this time used the precut option
much easier to fit
got the dark 20% tint
works well, but the tint ends right on my eyeline, would have prefered a graduated tint, but hey-ho
- jim
- Visitor
so off they came, and used some self tappers to screw some useful storage tins in their place
I'm easy pleased.
- Tadpole
- Visitor
Halford wrote: well after all this time, only just realised that the armrests unscrew from the rear panels
I'm easy pleased.
Neat but not gaudy .........
- Thank you received: 260
I'm easy pleased.
Have you thought of giving the tins a coat of matching paint?
So got the tape measure out
Measured from top of wheel arch to road (tyres inflated on level ground)
NS-Front 85.0 cm
OS-Front 83.5 cm
NS-Rear 85.5 cm
OS-Rear 84.0 cm
NS to door handle top 110.5 cm
OS to door handle top 110.0 cm
Bearing in mind its got new shocks and springs +2"
No castor correction
Whats going on ?
looks ok
- NineCherries
- Visitor
- Visitor
Will update when fitted or not fitted during investigation
- Visitor
