BigJimnyMeet 2024
Change defect dashlights
- funny16
- Visitor
30 Apr 2014 20:46 #113820
by funny16
Replied by funny16 on topic Change defect dashlights
Project finished.
Today i finished this project.
I could choose between led and a normal bulb of 12 volt. ( we have them at work )
So i choose for the normal bulb.
At the photo's you could see what i did....and it works!
Sorry for the last photo's, difficult to take that-one with the camera.
so project ends.
Next weekend I install my camera, i let you know!
grt
funn
so project ends.
grt
funn
- kalliohk
- Visitor
14 Mar 2017 19:46 - 14 Mar 2017 20:03 #179225
by kalliohk
Replied by kalliohk on topic Change defect dashlights
Hi all,
This is a little bit old topic, but I think this is still the best place to ask about the dashlights
I recently bought Jimny (model 2007) and now I noticed that my 'hazard light switch' and 'rear screen dimister / mirror heater switch' lights (bulbs?) are broken. I read some old topics etc. and I think that at least there is a replaceable bulb (I think it is T3 or something) in the side of hazard light switch. Does anyone have any better knowledge about the bulb, fe. dimensions (diameter)? Or photo of bulb? Or any advice for the replacement?
My other question is concerning the rear screen dimister (heater) switch, does anyone know is there replaceable bulb at all? Or is there any easy way to fix the light? I could not find any topics or photos concerning this heater switch light/bulb fixing.
I'll open the centre console in the next weekend (found the instructions, thanks) and check the switches, but I would really appreciate all the advices I can get concerning this job.
BR,
Kari
BR,
Kari
Last edit: 14 Mar 2017 20:03 by kalliohk.
04 Apr 2017 14:17 #179905
by asypeer
Replied by asypeer on topic Change defect dashlights
Sorry for the bump, but which bulb(s) do I need in order to replace the broken bulbs in:
1. heater control
2. 4WD buttons
its a 2006 jimny VVT. same as the topic author has, it seems that the links in the topic are not accurate.
can someone post the correct link for the above bulbs or just write the bulb model needed?
I dont want to disassemble the entire thing just to find out I'm missing the correct bulb..
thanks!!
1. heater control
2. 4WD buttons
thanks!!
- Darthblaker7474
- Elite Member
- Thank you received: 19
20 Apr 2017 01:28 #180418
by Darthblaker7474
Replied by Darthblaker7474 on topic Change defect dashlights
I'm not too sure about the heater controls, however I'll have a look tomorrow and see what size they are.
As for the 4WD controls, they take these: www.maplin.co.uk/p/coloured-subminiature-bulbs-red-pg78k
I tried LEDs first before reading the thread again when they wouldn't work, I'm assuming it was something to do with them not getting enough power
I looked on eBay for clear submini. bulbs but had no luck.
- Mraz
- Visitor
20 Apr 2017 04:18 #180419
by Mraz
Replied by Mraz on topic Change defect dashlights
Heater controls take two T5 bulbs. Originals have red silicone caps over them, but I threw them away. Now it's white and a lot brighter.
- Mraz
- Visitor
20 Apr 2017 08:01 #180425
by Mraz
Wait a minure.... buttone ARE iluminated? Geez. I figured mr. Suzuki was lazy since mine never worked. Now I need to change them.
- Darthblaker7474
- Elite Member
21 Apr 2017 20:51 #180466
by Darthblaker7474
I changed my heater control bulbs today, it was a right ball ache.
I found the best way to swap them over was to remove the stereo so you can get access from above to the one on the right and twist it out.
However the one on the left was trickier to remove properly, so I pulled the actual bulb from the little black holder by moving the thin plastic fascia to expose it.
Halfords sell the bulbs separately from the holders , but on eBay there's green ones which look pretty tempting
Looks nice for now anyway
- Mraz
- Visitor
22 Apr 2017 19:44 #180493
by Mraz
I couldn't find original bulbs and didn't want to wait so I did some soldering and now there are two T3 bulbs lighting up my buttons. They're a bit too bright but at least they work.
08 Jun 2017 20:38 - 08 Jun 2017 20:41 #181873
by asypeer
Ok so I finally had some time to change all the bulbs:
The AC light required a removal of the black background, the knobs to get to the bulb (the right one especially..)
The T5 leds fits perfectly, don't forget the tiny red rubber:
The 4WD switch also require a bulb change, I dont have time to wait for ebay so I just bought 2 T3 bulbs (we call them "rice bulb" here..)
Now I need to reassemble everything..
Last edit: 08 Jun 2017 20:41 by asypeer.
- Thank you received: 333
17 Jan 2018 08:23 #188469
Replied by yakuza on topic Change defect dashlights
These bulbs are not expensive from Suzuki original, and then you will get the correct ones right away and no hazzle.
17 Jan 2018 10:01 #188473
by 1390_taz
Replied by 1390_taz on topic Change defect dashlights
Many of us have the same issue and found this
www.jkllamps.com/incandescent/neo-wedgelamps
- florinelu07
- Visitor
17 Jan 2018 12:24 #188476
by florinelu07
Replied by florinelu07 on topic Change defect dashlights
Time to create page: 0.199 seconds
