BigJimnyMeet 2024
engine and gearbox removal
- nate78
- Visitor
02 Nov 2012 15:11 #51986
by nate78
Replied by nate78 on topic engine and gearbox removal
really?? i didnt know that, im glad you told me, i was under the impression that they would just bolt up, how much will that cost?
- Dave cc
- Visitor
02 Nov 2012 15:23 #51987
by Dave cc
Replied by Dave cc on topic engine and gearbox removal
I did my own was good few hours of pissing about not sure what a engine shop would charge guess £35 - £40 per piston
- nate78
- Visitor
02 Nov 2012 16:14 - 02 Nov 2012 16:30 #51992
by nate78
oh foook, would the 16v vitara pistons vit the 8v block?
looking on the net, g16a was used as the 8v and the 16v so im hoping that the pistons will be the same size just different cuts in the crown of the piston
Last edit: 02 Nov 2012 16:30 by nate78.
- Dave cc
- Visitor
02 Nov 2012 16:29 #51996
by Dave cc
Im not sure for definate on the 16valve pistons in the 8 valve block never done it although the bore is the same size i do know that the 1300 jimny pistons have there gudgeon pins held in with circlips and the 1600 8 valve pistons have sweat fit gudgeon pins so i would assume the 1600 16 valve pistons have retaining circlips so you may not be able to fit the 16 valve pistons to the 8 valve conrods pins plus 4 pistons will cost a fortune.Much easier to whip the pistons out and pop some pockets into them.aint no biggey if someone has the kit to do it as its only clearance as long as they match all the pistons will be happy days
- nate78
- Visitor
02 Nov 2012 16:34 - 02 Nov 2012 16:45 #51997
by nate78
i was looking at buying some 2nd pistons with conrods and replacing the rings, hmmm seems a pain in the ass, i will have to look into both options, there is a 1600 16v block on ebay with pistons and crank, as the early 16v and 8v shared the g16a block maybe they will fit
does anyone on here have the kit to bore out some 'pockets' in my pistons?
just been reading on another forum apparently the isnt an issue withthe vavles hitting the piston?? im not going to take that as gospel but something to look at, if only some was had been selling a 16v lump to go straight in to my jimny before i bought a 8v and all the brand new bits!
Last edit: 02 Nov 2012 16:45 by nate78.
- Dave cc
- Visitor
02 Nov 2012 21:16 #52036
by Dave cc
Well maybe there is no issue all i can tell you is there are 4 pockets in a jimny piston and 2 in a 8V vitara block i put them in to match like for like if they are not needed why are they there ?????????????????????????????????
- nate78
- Visitor
02 Nov 2012 21:39 #52038
by nate78
thats what i saw when i looked at pictures of 16v pistons, any idea if i could just swap over for 16v pistons with matching con rods? also do you have any pics of the engine mounts that you made?
- Dave cc
- Visitor
02 Nov 2012 22:09 #52045
by Dave cc
Will try and get you a picture tommorow or Sunday my engine is sitting in the garage as its up for sale
- nate78
- Visitor
02 Nov 2012 22:16 #52048
by nate78
i know, if i had seen it before i bought my 8v and bits i would of bought it off you, gutted!!
- nate78
- Visitor
03 Nov 2012 15:56 #52079
by nate78
ive just bought a 16v block with pistons so will be selling a 8v block with new headgasket and bolts soon!
- Dave cc
- Visitor
03 Nov 2012 22:47 #52174
by Dave cc
Sorted well done
- nate78
- Visitor
03 Nov 2012 23:56 #52185
by nate78
lets hope so! is the adapter plate for the SJ413/vitara from offroad armoury the same as the jimny one?
Time to create page: 0.105 seconds
