Is this normal fuel consumption normal???
- ZookFastback
- Visitor
- Dan13l
- Visitor
Can anyone give me a bitta insight I've done a bit of testing with the water temp and engine temp and I believe it could be a faulty thermostat but if where I believe it is, it's going to be a pain in the backside to do
Is it located pretty much right behind and underneath the intake manifold? And if so how can I remove it with our having to pull apart the rest of the engine to get to it haha?
Cheers
- Dan13l
- Visitor
- ne-crock
- Visitor
did you have any luck sorting it out, because i think there must be a problem with mine also?
- mark1971
- Visitor
- Thank you received: 584
- ne-crock
- Visitor
i'll give her a clean under and check for leaks she smells a bit of petrol when she's running but couldnt see any leaks when i looked
its a w reg softtop with 62k if that would make any difference
- markyp2000
- Visitor
Dan13l wrote: Yea I did and its just stats cold for ages then slowly starts to get warm but never to the point of not being able to touch it so I presume and hope that is the problem, but there is only one way to find out... Time to pull off the intake manifold
It sounds like its stuck open then, good luck with it. Doesn't look as straightforward as most cars.
- Dan13l
- Visitor
At half a tank with 225km out of it so Better already I hope this was the issue
