BigJimnyMeet 2024
Possible death wobble ?
- Thank you received: 2
25 Jul 2023 16:27 #249992
by neffy33
Replied by neffy33 on topic Possible death wobble ?
in this never ending drama .
I went back to the garage who put in my new tyres and as suspected the front two tyres needed a good balance,
The tyre guy was kind enough to tell me that my left hand tie rod was worn and needed replacing which maybe the other reason to my problems.
i am amazed that the prior mechanic did not notice it as he was the one replacing the wheel bearing .
I think i will get both tie rods replaced just to be on the safe side.
- Thank you received: 552
25 Jul 2023 21:45 #249998
by Scimike
Replied by Scimike on topic Possible death wobble ?
A worn tie rod component is going to influence the susceptibility to wobble or vibration, it's one of the many components that need to be in good order to prevent this. I am surprised it wasn't noticed during the alignment process, it's one of the components you adjust.
I would get whomever is going to fix this to check front wheel bearings, kingpin bearings, all ball joints on the steering and rubber bushes for play. If they don't know what these items are on the Jimny find another mechanic.
Good luck
M
Good luck
M
- Thank you received: 653
26 Jul 2023 16:02 #250008
Replied by jackonlyjack on topic Possible death wobble ?
I would advise changing all 4 tie rod ends 2 left hand threads and 2 right hand
28 Jul 2023 17:43 #250027
by neffy33
It seems that the mechanic who put in the new kingpin bearing didn't do a good enough job and now the left hand Bearing is leaking oil .Just curious if anyone has purchased a oem kingpin set .Does the set inculde parts to repair both kingpins ? i am definitely putting a complaint in as this is ridiculous at this point .
28 Jul 2023 19:57 #250029
Most kits available come with 2 bearings 1 oil seal for axle
Other kits come with swivel seal
1 kit does one side only
31 Jul 2023 19:09 - 31 Jul 2023 19:09 #250060
by neffy33
I have looked at the invoice from the garage that I got the kingpin repaired and as suspected they only fixed one kingpin when I assumed they would fix one.They obviously did not communicate this to me.I have attached picture of the leaking kingpin. I just find it weired how they fixed one kingpin and the passenger side kingpin goes right after .It consistently smells like diff oil when i go near my car eurgh.Looking at the pics what do people think? Shall i order the kingpin alongside a pair of shims? Or shall I just order a new swivel kit ? I've taken alot of pics for people to get a good view.
I have also attached a picture of the right side which they repaired
Last edit: 31 Jul 2023 19:09 by neffy33.
- Thank you received: 372
31 Jul 2023 22:34 #250061
Replied by DrRobin on topic Possible death wobble ?
The oil leak comes from the drive shaft seal, it must be leaking. These often go when the kingpin bearing wears and that also gives you the wobble.
The large swivel seal is just a dust seal to stop dust and water from entering the swivel.
When my kingpin bearings, I bought a kit of bearings, drive shaft oil seal and large swivel seal. I didn’t need shims. I suggest you need the same, kingpin bearings, oil seal and large swivel seal.
Strange the garage didn’t mention you needed both sides doing. Mind when mine went, only one was showing a little oil and had play, the other didn’t, so I only replaced one side, only to find it reduced the wobble but didn’t fix it completely. I then did the other side and the wobble was gone.
Robin
Robin
31 Jul 2023 23:33 - 31 Jul 2023 23:35 #250062
by neffy33
Thank you for getting back to me .
It does seem trying to find a reliable garage who are not willing to do half a job in Birmingham is pretty hard. I had this feeling that they somehow knew that the same thing would happen to the left side but we're too lazy to fix the issue.
Certainly not trusting them again.
I have found it to be a little more cost effective ordering the parts separately on ebay.
so will order all the parts in and see if this resolves the issue.
Last edit: 31 Jul 2023 23:35 by neffy33.
Time to create page: 0.133 seconds
