BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Wheels and tyres
17 Jan 2019 18:18 #200990 by jackonlyjack
Replied by jackonlyjack on topic Wheels and tyres
Cremator1 wrote: Jack u buy them lol go on lol what was wrong with the ones I sent u
The one's you posted are for Jakkarta wheels the 60 degree tapper has to be from nut face NO flat insert
  • Cremator1
  • Visitor
  • Visitor
17 Jan 2019 18:19 - 17 Jan 2019 18:21 #200991 by Cremator1
Replied by Cremator1 on topic Wheels and tyres
Ah ok that was a waste of money then gv24 from this site said I could use them great lol
Last edit: 17 Jan 2019 18:21 by Cremator1.
  • Lambert's Avatar
17 Jan 2019 18:27 #200993 by Lambert
Replied by Lambert on topic Wheels and tyres
And you're going to keep pouring good money after bad until you've measured the actual wheel you're fitting, there's too many variations of nut seats on aftermarket wheels.
  • Cremator1
  • Visitor
  • Visitor
17 Jan 2019 18:34 #200994 by Cremator1
Hi but I don’t no how to measure it
  • Lambert's Avatar
17 Jan 2019 18:45 #200995 by Lambert
Get a protractor just a cheap plastic school one and rest it across both edges of the nut hole in the wheel, then with a suitable straight edge that is narrow enough to fit through the hole and rest on the chamfer. Use this to read off the angle on the protractor. If the straight edge only touches on two points when through the hole and you can see daylight in a small semi circle then the seat is a radius and measuring that is more involved.
17 Jan 2019 18:48 #200996 by jackonlyjack
Just found some modulars in the usa and it says 60 degree
ckspacing (in)
4.000 in.
Beadlock Functional
No
Beadlock Included
No
Center Cap Included
No
Hub Centric
No
Lug Nut Seat Style
Conical seat - 60 degree
Manufacturers Wheel Series
Bart Wheels D Trucker Series
Primary Wheel Color
Black
Quantity
Set of 4
Recommended Valve Stem
7/16 in. pull-through or bolt-on
Valve Stems Included
No
Wheel Construction
2-piece
Wheel Diameter
15 in.
Wheel Finish
Gloss
Wheel Material
Steel
Wheel Width (in)
8.000 in.
  • Cremator1
  • Visitor
  • Visitor
17 Jan 2019 18:51 - 17 Jan 2019 18:52 #200997 by Cremator1
Ok guys so we no it is 60 degree so I should be ok with the nuts that held my alloys on as they are 60 degree
Last edit: 17 Jan 2019 18:52 by Cremator1.
17 Jan 2019 18:58 #200998 by jackonlyjack
Yes and just to be sure if you remove one nut and look at the wheel you should be able to see where the nuts marked the paint
also paint may have transferred onto the nut should be a mark around 2.5mm from the nut face :)
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
17 Jan 2019 19:08 - 17 Jan 2019 19:17 #200999 by Riccy
Replied by Riccy on topic Wheels and tyres
Put it this way...
If the wheels are staying on and you haven't got any wheel wobble they are working ;-)
Fitting nuts that are wrong will bugger up the wheel balance and possibly damage the wheel. Driving at low speeds wouldn't be noticed, but get up to 65-70mph and it will be shaking worse than Elvis.
A easy test, to be certain, would be to take a wheel off and try sitting a wheel nut in one of the holes. if it fits snug then and doesn't wobble about easily then all is well, if its slipping around and not matching the shape of the hole, it is wrong. Nice simple test ;-)
Last edit: 17 Jan 2019 19:17 by Riccy.
  • Cremator1
  • Visitor
  • Visitor
17 Jan 2019 19:12 - 17 Jan 2019 19:12 #201001 by Cremator1
Hi Riccy ok I will try that tomorrow but I am sure they sit in the hole fine
Last edit: 17 Jan 2019 19:12 by Cremator1.
  • Lambert's Avatar
17 Jan 2019 19:26 #201004 by Lambert
So what, if you're happy with the nuts sitting in the holes, is actually causing you concern?
  • Cremator1
  • Visitor
  • Visitor
17 Jan 2019 20:00 #201008 by Cremator1
I asked if my alloy wheel nuts would be ok with these wheels and was told I needed steel wheel nuts for them
Powered by Kunena Forum
