To lift, or not to lift...
- Max Headroom
- Banned
- Thank you received: 217
There are some excellent and very constructive replies here.that do help me too; I have some crabby looking springs on my Jimny one of which feels significantly weaker so I'm looking at replacing the springs.
I already elected for Monroe shocks based on the experiences of other users, so will probably look for standard springs to go with them, but as yet I'm still a little undecided - one part of me is arguing that if I'm replacing all these suspension components why not include a (2") lift at the same time? However the other part of me is arguing that I'm mostly going to be on the road with the car so why bother!
A dilemma of my own making.
The other confusion for me is the unequal values on the rear springs to compensate for the (apparent) "lean" that Suzuki perceive the Jimny to have from the combined weight of fuel tank and driver in RHD cars.
There seems to be a confusing array of spring choices - granted most of the choices are to do with height. But how critical is this lean issue actually?
I'm sure someone on the forums mentioned to try using 2 x (RHD) rear springs. Has anyone actually done this, and what was the result?
From what I have read recently the steering damper mod is a must so I will be embodying that on the car at some stage.
- Thank you received: 225
Thanks Ola. The only research that I have previously done of the more "standard" dampers was with Bilstein. There are Bilstein dampers that have a compressed length less than the 312 and extended length greater than the 455. I’m guessing that it shouldn’t be too difficult to find others. Keeping the travel in context, the front is 143mm (5 5/8 inch for us Americans) and a little less in the rear. That isn’t overly extreme.OlaGB wrote: Great info!
Do you know if the more known shocks we use for lift has longer travel than stock , so it gives this maximum travel?
As it stands now, of the members replying to this thread, you, Lambert and Furo have Trailmaster which is a quality kit. Chris may end up with one too. I’m not sure you could do much to improve what you have. If so, it wouldn’t be much. The dampers in the comfort kit (I’m attaching a Trailmaster file) have a compressed length of 275. I would suggest that you avoid bumpstop extensions which rob you of travel (but confirm you’re hard on bumpstop without bottoming out the damper). Also to Busta’s point, if you are looking for flex, I would suggest that, in spite of numerous disadvantages, you stay with rubber bushes. The poly bushes do have advantages but flex isn’t one of them.
- ChrisW
- Visitor
Brake cables, I will do the rear disc conversion before hand and replace the brake lines with braided.
I am leaning towards going for the 2 inch trail masters, as the reviews on comfort and the reduction of the jolt from poor roads are really good.
- Thank you received: 305
I think a lot of the impact that a small lift gives when fitted, is no different.
You've taken tired original components and changed them for fully functioning new components. The "lift" is pretty secondary...... the impact of new suspension on a tired old chassis is quite remarkable.
sniper
I think jackonlyjack runs 3" arms with a 2" lift, he says it drives great.
Lots of people have said good things about that trailmaster kit.
sniper
- Thank you received: 653
Some people don't fit castor corrected bushes either
fit the 2" lift and see how it feels to drive then decide if you want to fit castor correction bushes
One thing to mention with the trailmaster kit - I have found it to be very high quality BUT I got Jimny-lean after installing it and needed to get a spacer for the front driver spring.
Busta - I don't know ratings but the trailmaster springs are extremely supple, they definitely feel less stiff than stock
- ChrisW
- Visitor
@furo, is the Jimny Lean a lean to the side or front to back? Never really understood it.
I think overall I have kept myself sold on getting the kit, just comes down to when. Seams like a summer project. Got lots of other work to do before it gets installed.
- Thank you received: 1761
The lean is to the driver side of the car if both pair of springs are the same length and force. Front springs are longer than rear ones.
- Thank you received: 333
Mine do not lean i think. haven't noticed.
most important to me was to make space for 235's
