BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
engine swap to g16b queries
  • suzukisam
  • Visitor
  • Visitor
06 Nov 2014 20:02 #128755 by suzukisam
engine swap to g16b queries was created by suzukisam
I have just got a g16b engine from a baleno but need to swap camshaft from my g13b now ive heard it wont rev as high if I do this ?
Is this true and does it affect it much or is it not really noticeable
Cheers sam
06 Nov 2014 20:29 #128762 by j999pre
Replied by j999pre on topic engine swap to g16b queries
If the Jimny cam and the baleno cam are the same diameter on the cam pick up end you could swap the 2 lobe ring for the 11 lobe. The cam would then rev as normal. You would have to make sure you got in exactly the same place by marking the 2 cams up first. A little bearing puller should pull it off ok.
Grey pick up Jimny
  • suzukisam
  • Visitor
  • Visitor
06 Nov 2014 20:49 #128764 by suzukisam
Replied by suzukisam on topic engine swap to g16b queries
j999pre wrote: If the Jimny cam and the baleno cam are the same diameter on the cam pick up end you could swap the 2 lobe ring for the 11 lobe. The cam would then rev as normal. You would have to make sure you got in exactly the same place by marking the 2 cams up first. A little bearing puller should pull it off ok.
Cheers james all sounds like scary work lol if I decided to run the jimny cam is it a massive difference or not really noticeable ?
07 Nov 2014 08:26 #128792 by j999pre
Ask vitmad I think he has used the Jimny cam in a g16.
Grey pick up Jimny
  • vitara_mad
  • Visitor
  • Visitor
09 Nov 2014 09:47 #128986 by vitara_mad
Replied by vitara_mad on topic engine swap to g16b queries
yes ive used jimny cam in baleno engine & found it to be fine
  • TomDK
  • Visitor
  • Visitor
09 Nov 2014 09:56 #128987 by TomDK
Replied by TomDK on topic engine swap to g16b queries
But why not just change the pick up cam. It is very easy to do, and there are already marks on the pick up and the cam shaft it self. I did it when I changed camshafts and head.
09 Nov 2014 11:55 #128999 by gus2000
Replied by gus2000 on topic engine swap to g16b queries
Hello.
A question. Would it be interesting to verify that the g13 and g16 camshaft had the same lift and the same angles of opening and closing of the valves?
This would allow interchangeability without affecting G16B engine performance
Thanks
Gustavo
Gustavo LU2HC - Rio Cuarto (Argentina)
Jimny 1999 - 1.6 16V - SOHC
09 Nov 2014 14:02 #129008 by Rhinoman
The G16B camshaft has a longer duration, I think that it has a little more lift too.
The following user(s) said Thank You: gus2000
  • Cider
  • Visitor
  • Visitor
09 Nov 2014 21:25 #129069 by Cider
Replied by Cider on topic engine swap to g16b queries
Both GV 1.6 and jimny 1.3 have the same lobe measurements "info form Suzuki workshop manuals"But different
cam pick up not sure with Baleno
  • suzukisam
  • Visitor
  • Visitor
09 Nov 2014 21:38 #129073 by suzukisam
TomDK wrote: But why not just change the pick up cam. It is very easy to do, and there are already marks on the pick up and the cam shaft it self. I did it when I changed camshafts and head.
What do mean did you pull the part with the 2 lobes off the camshaft and swap it with the jimny one ?
If so what did you use james mentioned a small bearing puller ?
Cheers for the help guys
  • TomDK
  • Visitor
  • Visitor
09 Nov 2014 21:57 #129077 by TomDK
Yes.
My Jimny is a 2003 RHD softtop which has the camshaft pickup ring with 2 lugs.
Some months ago the camshaft seized in the head, so I had to find a new head and camshaft. But here in Denmark we only have Jap built Jimnys with the camshaft with 11 lugs on the pickup ring.
So long story short, I used a standard puller to pull the 2 lug ring off the old ruined camshaft and put it on a new used camshaft I got from a breaker.
When you hold the two camshafts up next to eachother you'll see that it's not that hard to swap these pickup rings. But off course always make a few marks, just in case. I you want, I can take a few pics of the old camshaft and ring tomorrow :)
  • suzukisam
  • Visitor
  • Visitor
09 Nov 2014 23:01 #129080 by suzukisam
Yes.
If you could that would be great thanks
Time to create page: 0.129 seconds
Powered by Kunena Forum
